![]() | Home > General (L494) > JLR Dashcam |
Damon White Member Since: 15 Feb 2016 Location: London Posts: 62 ![]() ![]() ![]() |
scrumps Member Since: 01 Aug 2011 Location: Somerset Posts: 583 ![]() ![]() |
jd2uk Member Since: 01 Apr 2017 Location: Kent Posts: 109 ![]() ![]() |
I did this on my car. I think it's the most common method for installation of the rear cam on the RRS. Removing the spoiler is relatively easy - Powerful UK have a good video on YouTube. |
MrM Member Since: 16 Jan 2016 Location: London Posts: 146 ![]() |
How easy was it to feed the usb cable through the rubber grommet once the spoiler was off? |
Easy enough, but you'll need to use something to push it through. If you use a wire coat hanger make sure the end doesn't have any sharp edges (wrap plenty of electrical tape around it) and go gently - you don't want to damage the insulation on any of the wires in the original loom |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9136 ![]() ![]() ![]() |
PowerfulUK have a comparison of the LR camera and an off the shelf NextBase unit in this video.
pjbracer1 Member Since: 25 Aug 2014 Location: Southampton Posts: 413 ![]() ![]() |
I got Blackvue DR750CHS 4K Colour/night, wifi and BT front and rear and they were about £280 for the pair and the power, got a local sparks to tap into the power above the rearview mirror and all works great, the only |
Harveyp500 Member Since: 08 Mar 2016 Location: Worcester Posts: 61 ![]() ![]() ![]() |
Hi Guys,
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 932 ![]() ![]() |
I'm with you, its a dashcam, I'm not filming the next Tom Cruise blockbuster. As long as it works fine, I will probably never look at the footage after trying it out. (Unless there is an accident) Mine is a bit more than £17 but less than £35 from memory. Starts fine, films fine with good definition reads number plates, switches off fine. & its nice and small |
abiopete Member Since: 27 Feb 2020 Location: Manchester, UK Posts: 184 ![]() ![]() ![]() |
Anyone know how to export a video from the app? Managed to download it to the iPhone but cant figure out how to send it.. L494 3.0L SDV6 Autobiography MY20 in Eiger Grey (Current)
can you browse the footage in photos/videos on the iphone? maybe try save to files (which you can then send on) Or does it have a cloud option so that you can upload to the cloud when you are at home on your wifi and initiate it from the app on your phone perhaps.
No, not as far as i can see. You have the option to download the video from the webcam to the device but as far as i can see its only visible through the app. Definitely nothing in the pictures folder
Check the app settings and see if it has access to your photos on the iphone if that has been denied then it will store them inside the app I suspect. (have you connected the phone to a PC or and seen if you can browse it? Seems odd that is wouldnt allow you to email or send them on somewhere, only thing I cant think is that when it intstalled it didnt ask for access to the photos folder on your phone which I would naturally deny unless I had a reason!
rjwojcik Member Since: 05 Oct 2013 Location: Essex Posts: 27 ![]() ![]() |
Any ideas what make the JLR dash cams might be? |
