![]() | Home > Technical > Sport won't start if left for a day |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 965 ![]() ![]() |
So it starts if jump started - sounds like a battery issue (yes I see you have replaced the battery but if it needs jump starting it is a battery issue. 07MY RRS TDV6
Smarttech Member Since: 11 Jan 2017 Location: West Sussex Posts: 397 ![]() ![]() |
If the battery has been changed and it's any good then that would point to something is being left on or not shutting down and drawing current to flatten a battery in 24 hours.
riverblanche Member Since: 11 Jun 2011 Location: Retford'ish Posts: 926 ![]() ![]() |
Taff814 Member Since: 19 Dec 2020 Location: Dereham Posts: 2 ![]() ![]() ![]() |
Thanks to you all for your replies. I'll have a chat with her about testing the voltage before she opens the car. This is the second new battery its had in 5 months. Previous owner changed it in Sept |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 7410 ![]() ![]() ![]() |
How long are the drives when it is jump started? If it's short journeys then the battery will never recharge. Indeed, it's possible that the alternator is dying and the battery has no chance to recover.
evets Member Since: 11 Jun 2020 Location: Manchester / Bolton Posts: 28 ![]() ![]() ![]() |
The secret menu on a range rover tells you what voltage the battery has.
Site Copyright © 2005-2021 Futuranet Ltd & Martin Lewis
