![]() | Home > Technical > Restricted performance |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9156
A split intake manifold can cause this error. Realistically you need to have error codes checked and there are a number of possible causes. 2012 SDV6 - it's missing a couple of cylinders
| Puslinch Member Since: 08 Jan 2017 Location: Surrey Posts: 208
Mine was a split cross over pipe at the rear of the engine. No codes appeared, just restricted performance. 2018 Telsa MS
| Tyrefitter Member Since: 19 Jul 2015 Location: Bridlington East Yorkshire Posts: 3677
Throttle body sticking. Andy.
Pull the metal clip up marked yellow,pull pipe off & spray with throttle body cleaner.
I'll throw in a MAF sensor |
| Father Jack Member Since: 16 Oct 2016 Location: Edinburgh Posts: 480
The twice I had intermittent fails like the op that cleared on cycling the ignition it was inlet manifolds. That there are many other suggestions is testament to legendary JLR design and quality |
Double post deleted |
| All times are GMT |
