Home > Technical > Restricted performance
Denny2789
England 2013 Range Rover Sport SDV6 HSE Baltic Blue
Restricted performance warning on rrsport sdv6 2013. Seems to happen when cold, if driving above 70 mph. When I restart car all ok.
What could be the problem. Had the car six months and has happened twice.
Post #609973 Sun Feb 14 2021 1:45pm
A split intake manifold can cause this error. Realistically you need to have error codes checked and there are a number of possible causes. 2012 SDV6 - it's missing a couple of cylinders
Post #609985 Sun Feb 14 2021 7:03pm
Puslinch
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Firenze Red
Mine was a split cross over pipe at the rear of the engine. No codes appeared, just restricted performance. 2018 Telsa MS
2012 Range Rover Sport HSE+
1990 Porsche 944
1985 LR 90 Soft top V8
Post #610119 Tue Feb 16 2021 10:32pm
Tyrefitter
Throttle body sticking. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #610202 Thu Feb 18 2021 5:55pm
Tyrefitter
Pull the metal clip up marked yellow,pull pipe off & spray with throttle body cleaner.
 Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #610203 Thu Feb 18 2021 5:59pm
Disco_Mikey
I'll throw in a MAF sensor Thumbs Up
Post #610204 Thu Feb 18 2021 6:03pm
Father Jack
Scotland 2012 Range Rover Sport SDV6 HSE Santorini Black
The twice I had intermittent fails like the op that cleared on cycling the ignition it was inlet manifolds. That there are many other suggestions is testament to legendary JLR design and quality Smile. Get to a good indy and get the codes read would be my advice.
Post #610288 Sat Feb 20 2021 12:54pm
Father Jack
Double post deleted
Post #610289 Sat Feb 20 2021 12:55pm
