Home > In Car Electronics > Rear screen question |
MarcMGD Member Since: 30 Nov 2020 Location: Essex Posts: 22 |
Has anyone done this? Looking at the OEM retrofit guide it appears I *might* be able to connect the rear screens threw a few svideo connectors and adaptors? Can anyone shed any light on this? |
Sun Feb 14 2021 2:20pm |
scarey Member Since: 07 Jan 2011 Location: in the cloud Posts: 410 |
try using the forum search function.. |
Sun Feb 14 2021 3:02pm |
Hi, I have tried using the search function but haven't found the info I am looking for. I have been searching searching Web since November. I have also only stumbled across the oem retrofit guide but it doesn't explain how to get rear screens to display video/dvd from the front screen on them.
Sun Feb 14 2021 7:12pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4845 |
That retro fit guide is for the TV tuner not the factory RSE system, on a 2012 car I think you will find the TV tuner is under the front seat and the RSE module is behind the r/h trim panel in the boot, if you remove the small access cover in the boot panel you can just about see it along with the DAB receiver and audio amp but to get to it you would need to remove the whole panel, may be possible to link the aftermarket screen through it via original module, but not being a audio/video engineer wouldn't know if that can be done. Do you have the original remote control and docking station in the rear armrest?
Sun Feb 14 2021 10:48pm |
Hi Col,
Fri Apr 02 2021 11:23pm |
Are you sure your car had the RSE originally ? as Topix has been known to be wrong. As I said have a look at your rear armrest it should look like the pictures below even if it doesn't have the remote in it. I can't think anyone would change the armrest as well if they removed the original screens or remove the headlining transmitter. I believe Chris aka Brit Plumber may have retro fitted a o.e system, might be worth dropping him a pm.
Sat Apr 03 2021 2:49am |
