![]() | Home > In Car Electronics > L320 MY2013 360degree camera - not surround.. |
cassman Member Since: 09 Nov 2020 Location: Essex Posts: 71 ![]() ![]() ![]() |
Hi all,
I think I need to ask someone where the rear view camera input goes on the system. Which box does it plug into?
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5096 ![]() ![]() ![]() |
It plugs into the screen !
Whats the box under the drivers seat in a 2013 L320 actually do then?
Amplifier I thought |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5093 ![]() ![]() ![]() |
The box under the drivers front seat on a 2013 car is the TV tuner, the Amp is behind the r/h side trim panel in the boot. The O.E module for surround cameras is under the passengers front seat, but as you don't have them it will not be there, the single rear view camera layout is very basic and as said feed goes to the front screen and is not controlled by any module.
Hi Col,
It's CAN.
Ace thanks Col.
jimbg Member Since: 29 Jan 2013 Location: No longer by the River Dart.... Posts: 1903 ![]() ![]() |
Contact member Brit Plumber, he has done quite a few mods to his car. 2023 P440e SE Dynamic on order -cancelled
thanks jimbg ! Current car - 2016 MY17 L494 in black - sometimes towing a Buccaneer Cruiser.
Could you not wire them in as a separate system with a switch, the factory surround cameras on the RRS1 do not come on automatically and have to be activated via a touch screen icon and do not switch on when reverse engaged only the reversing camera. If you want the cameras to work all the time on the move forward you need to switch them on before you actualy move otherwise they switch off above a certain speed, I can't remember what speed as I rarely use mine, as they are not what could be described as "state of the art" but to be fair I suppose the technology for the original system is rather old and dated now by todays standards.
Hi Col,
