![]() | Home > General > Programming new key - anyone heard of this error? |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5082 ![]() ![]() ![]() |
I think you may find L/R have updated the KVM module numerous times due to security issues, it's only a suggestion but you may find your new key is not compatible with the original KVM module, the part I would be slightly concerned with is if you fitted the later KVM to suit new key it may not be compatible with the one original key you have and still only be left with one key. As I say It is only a thought but may be worth checking out with L/R before spending any more money.
Vermont_Jack Member Since: 18 Jan 2021 Location: Haywards Heath Posts: 11 ![]() ![]() ![]() |
Thanks for your reply Col.
Goffy Member Since: 31 Oct 2018 Location: Milton Keynes Posts: 82 ![]() ![]() ![]() |
This sounds familiar. I have a 2010 MY L320 which came with only one key, so I asked my Indy from whom I bought the car to get a second, also to delete the missing key from the system.
Update:
Well done, glad to hear that you've fixed the problem.
Micksandy Member Since: 28 Jan 2023 Location: Preston Posts: 3 ![]() ![]() ![]() |
Iv got same problem ordered a Dpla one off eBay car had a ah42 kvm in. Can this be done on sdd as normal? |
