![]() | Home > Technical > RRS Reverse camera. |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145
It’s not factory
| psxnet Member Since: 10 Dec 2020 Location: Lincoln Posts: 9
Thanks for the reply Andy.
https://www.rrsport.co.uk/forum/topic55655.html
Well the D4 screen is almost installed apart from fitting the rear camera somehow and connecting the extended fakra cable.
Pins 2 & 5. Middle pins for camera. (On 6 pin connector )
Your nav all working ok ?
This is the expensive camera connector
Sat Nav seems to be there but have to connect the fakra extention and abs wire still as I ranout of daylight today |
If you don’t want to run a new abs wire in, I used a redundant green wire and then put the red loop wire on the dvd connector under the seat.
I used your tip with the link wire Andy, a bit neater than running another.
So you should be able to see if the camera works and is correctly wired.
While in the test menu
| Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1057
Secret menu screen wouldn't show me any kind of video, or black screen even to start with.
| All times are GMT |
