Home > Technical > RRS Reverse camera. |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4798 |
It’s not factory
Fri Jan 22 2021 7:38pm |
psxnet Member Since: 10 Dec 2020 Location: Lincoln Posts: 9 |
Thanks for the reply Andy.
Fri Jan 22 2021 9:47pm |
https://www.rrsport.co.uk/forum/topic55655.html
Fri Jan 22 2021 10:06pm |
Well the D4 screen is almost installed apart from fitting the rear camera somehow and connecting the extended fakra cable.
Fri Jan 29 2021 6:47pm |
Pins 2 & 5. Middle pins for camera. (On 6 pin connector )
Fri Jan 29 2021 7:25pm |
Your nav all working ok ?
Fri Jan 29 2021 7:56pm |
This is the expensive camera connector
Fri Jan 29 2021 10:06pm |
Sat Nav seems to be there but have to connect the fakra extention and abs wire still as I ranout of daylight today The compass is working at the moment though, which it didn't before, but its about 90 degrees out, I presume that will fix itself when the GPS comes on stream.
Fri Jan 29 2021 11:12pm |
If you don’t want to run a new abs wire in, I used a redundant green wire and then put the red loop wire on the dvd connector under the seat.
Fri Jan 29 2021 11:42pm |
I used your tip with the link wire Andy, a bit neater than running another.
Sun Jan 31 2021 12:08am |
So you should be able to see if the camera works and is correctly wired.
Sun Jan 31 2021 8:11am |
While in the test menu
Sun Jan 31 2021 9:04am |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1048 |
Sun Jan 31 2021 12:14pm |
Secret menu screen wouldn't show me any kind of video, or black screen even to start with.
Wed Feb 03 2021 6:44pm |
