![]() | Home > Technical > Suspension control module A |
You need better diag gear... |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159
The error code is missing two digits. As D_M alludes, the diagnostic kit you have isn't reading the whole of the code and thus not giving you the bit at the end that points to the problem. 2012 SDV6 - it's missing a couple of cylinders
And the lost comms code is not the root cause of your fault, that is a cascade fault
| Simon_CSK Member Since: 21 Dec 2020 Location: East Ayrshire Posts: 70
I have a series of Fault codes which were read from a Snap on reader.
Focus on the C1A13 |
Thanks again Mikey.
No, you have an issue with the exhaust valve
Will need to get my own code reader as this seems to be a common problem I have with the codes. i.e.they are not specific.
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5155
Can only see one code beginning with C1A13 and that ends 64. Strange as slight difference in possible cause between 05-09 & 10-13 cars, first picture 05-09 second one 10-13 assume there must be some difference in design of system.
Thanks Col
Partial success giving big improvements.
Mikey
Perhaps...
| All times are GMT |
