Home > Technical > Suspension control module A
Simon_CSK
Am getting an error code on my TDV8 which is U0421.
When I look it up it refers to suspension control module A. My guess is that is one of the valve blocks and the letter A indicates the front one. Am I right or totally off the mark.
Help apprecaiated. Current cars
Range Rover Sport HSE TDV8
Range Rover TDV8 Vogue
Range Rover P38 Vogue
Range Rover CSK
Discovery 3 HSE
Post #609161 Mon Jan 25 2021 7:40pm
Disco_Mikey
You need better diag gear...
Post #609169 Mon Jan 25 2021 8:58pm
The error code is missing two digits. As D_M alludes, the diagnostic kit you have isn't reading the whole of the code and thus not giving you the bit at the end that points to the problem. 2012 SDV6 - it's missing a couple of cylinders
Post #609172 Mon Jan 25 2021 9:40pm
Disco_Mikey
And the lost comms code is not the root cause of your fault, that is a cascade fault
What are your symptoms?
Post #609181 Mon Jan 25 2021 10:08pm
Simon_CSK
I have a series of Fault codes which were read from a Snap on reader.
Codes I have relative to the faults (Have some relating to seatbelts and weight switch)
C1A13 Compressor Exhaust
U0434 Active Roll Control Module
U0421 Suspension Control Module A
U1A3B
I bought the car with the faults. The suspension is not rising evenly, The car flashes up with an error message telling me to stop the car and switch off the engine. I have changes the Active Roll Control Module but nothing changed.
I intended to take it to my local independent LR dealer to get it read properly however my other vehicles have problems and have nothing capable of towing the trailer.
When the fault codes were cleared it allowed access very temporarily to the height controller on the suspension. This allowed the back to be lifted but the front stayed down. This led me to thing it was the front valve block. Current cars
Range Rover CSK
Discovery 3 HSE
Post #609193 Mon Jan 25 2021 11:25pm
Disco_Mikey
Focus on the C1A13 Thumbs Up
Post #609204 Tue Jan 26 2021 7:24am
Simon_CSK
Thanks again Mikey.
So the most likely cause is a blockage to the compressor? Current cars
Range Rover CSK
Discovery 3 HSE
Post #609208 Tue Jan 26 2021 9:08am
Disco_Mikey
No, you have an issue with the exhaust valve
The final 2 digits of the code would narrow things down massively
Post #609212 Tue Jan 26 2021 10:07am
Simon_CSK
Will need to get my own code reader as this seems to be a common problem I have with the codes. i.e.they are not specific.
Two more questions if you don't mind.
1. Where is the exhaust valve located? I guess this is something on the suspension pump.
2. Is it the came for the Disco 3? Current cars
Range Rover CSK
Discovery 3 HSE
Post #609226 Tue Jan 26 2021 1:37pm
Can only see one code beginning with C1A13 and that ends 64. Strange as slight difference in possible cause between 05-09 & 10-13 cars, first picture 05-09 second one 10-13 assume there must be some difference in design of system.
Post #609232 Tue Jan 26 2021 8:31pm
Simon_CSK
Thanks Col
It is a 2008 model, I have ordered a new compressor as I don't have an Hitachi one to swap over. All other parts I have got some hopefully I will have it cured very shortly. Current cars
Range Rover CSK
Discovery 3 HSE
Post #609240 Tue Jan 26 2021 11:02pm
Simon_CSK
Partial success giving big improvements.
Got the new compressor this afternoon and despite the grey weather decided to fit it. After a lot of cursing and swearing I managed to get the old one out and replacing the allen key bolts with normal hex head bolts refitted it and reassembled all the pipes and electrical fittings.
Then I started her up and the suspension went up and down as it should and is now sitting level which it never did since I got it. Now the suspension is working properly the computer isn't over riding it and putting the car into limp mode however the dash still comes up with the error message:
Suspension fault
Stop safely
Turn engine off.
I suspect that now relates to the Anti Roll Control Module fault, Am I correct? or is it Suspension Control Module A?
I don't have a computer so the other option is I need to clear the faults. Current cars
Range Rover CSK
Discovery 3 HSE
Post #609311 Thu Jan 28 2021 6:24pm
Disco_Mikey
https://www.rrsport.co.uk/forum/topic57409.html
Neutral
Post #609319 Thu Jan 28 2021 8:08pm
Simon_CSK
Mikey
The Anti Roll Control Module has been changed. Current cars
Range Rover CSK
Discovery 3 HSE
Post #609321 Thu Jan 28 2021 8:15pm
Disco_Mikey
Perhaps...
Its time to down tools, pay for an hours diagnostics, and let a garage tackle it...
Post #609334 Fri Jan 29 2021 8:38am
