| RRSPORT.CO.UK | ||
|  | Home > Technical > Possible oil leak from left bank, help! |
| drexal Member Since: 17 Dec 2019 Location: london Posts: 121      |
 Hello all,
|  Fri Jan 22 2021 1:13pm |
| drexal Member Since: 17 Dec 2019 Location: london Posts: 121      | Hi Andy, thanks so much for replying. Ahh ok, that doesn't sound so bad. Do you have a rough ball park figure how much a independent specialist would charge for a cam cover gasket change?
|  Fri Jan 22 2021 5:32pm |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145      | Maybe 1.5 hours to change gasket on 4.2
|  Fri Jan 22 2021 6:45pm |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156      | I think you will find you may have to remove the Supercharger on a 5.0L to gain access to the cam cover inner retaining bolts, there is also a special tool to align the cover when refitting. Could also check for any excessive backlash in the s/c nose cone as the tvs1900 s/c did suffer a bit with wear in the torsional isolator coupling and spring which I believe made a rattling knocking noise. If you remove  the s/c belt not to difficult to do, should be able confirm if that is the noise though.
|  Fri Jan 22 2021 10:08pm |
| drexal Member Since: 17 Dec 2019 Location: london Posts: 121      | Thanks both for replying. Wow you guys are so knowledgeable. If this was your car would u attempt to try an replace the gasket yourself or would I give to a independant specialist?
|  Sat Jan 23 2021 7:39am |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156      | I recently replaced both the accessories and supercharger belts on mine, S/C one is easy as comes off first, just had a read of the Powertrain section of the W/Shop manual for the 5.0L S/C engine first.
|  Sat Jan 23 2021 8:40am |
| drexal Member Since: 17 Dec 2019 Location: london Posts: 121      | Hi Col, thanks again for always replying, i wish i could find a way to upload or send you the video, the knocking sound is very faint. But i don't remember hearing this in the past.
|  Sat Jan 23 2021 10:29am |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156      | Before or after the Vin No. I quoted. do you not have a copy of the W/Shop manual?
|  Sat Jan 23 2021 10:45am |
| drexal Member Since: 17 Dec 2019 Location: london Posts: 121      | Hi Col, my vin says something like CA7odd Iβll find full number when I get in if it helps?
|  Sat Jan 23 2021 11:31am |
|  Sat Jan 23 2021 8:20pm |
|  Sun Jan 24 2021 10:28am |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156      | Time is something I have quite a bit off these days as called it a day and decided to retire to NZ.   | ||
|  Sun Jan 24 2021 8:18pm |
| Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 784      | Whilst I'm not a big fan of black cars (wash it, drive it; dirty again   | ||
|  Mon Jan 25 2021 7:28am |
| drexal Member Since: 17 Dec 2019 Location: london Posts: 121      | Wow Col,
|  Mon Jan 25 2021 10:00am |
| Posting Rules
 Really sorry my mistake the the vin. I quoted is for the fullfat, it should have been CA759577 for the Sport, if after that it should hopefully have the modified tensioners.
 . ππ»ππ» You are a legend.
 Try this link to the Owners Manual, it is for the MY2012-2013 as the MY2010-2011 did have a couple of minor differences I believe.
