Home > In Car Electronics > 2010 Facelift wiring diagrams
Wafoo
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Baltic Blue
I'm chasing a wiring issue om my 2010 Facelift with the license plate lights not working, I've got hold of a original RRS wiring diagram but it's a bit different on the facelift with connector numbers etc, I've hunted high and low and can find nothing
TIA
Post #608783 Mon Jan 18 2021 2:19pm
This is the manual for the 2013 L320. Does that help?
https://www.mediafire.com/file/t7a6drmb6m4...3.rar/file 2012 SDV6 - it's missing a couple of cylinders
Post #608786 Mon Jan 18 2021 2:40pm
Try page 8.
https://drive.google.com/file/d/1UsGkAGdXm...sp=sharing
Post #608791 Mon Jan 18 2021 4:00pm
Wafoo
It does for routing Smile
But no wiring diagrams,, Sad
Post #608792 Mon Jan 18 2021 4:09pm
Wafoo
Col wrote:
Try page 8.
It doesn't load mate
Post #608793 Mon Jan 18 2021 4:13pm
Not sure why, it certainly does if I click on it myself, try this one.
https://drive.google.com/file/d/1totU9g9fJ...sp=sharing
Post #608794 Mon Jan 18 2021 4:23pm
Wafoo
Cheers Col, it works, it was my works computer didn't want to play, fine on my phone Smile
Post #608795 Mon Jan 18 2021 4:37pm
Probably security setting so you can't view naughty stuff. Whistle
Post #608796 Mon Jan 18 2021 4:41pm
Wafoo
Censored
Post #608798 Mon Jan 18 2021 5:12pm
Jabba
United Kingdom 2010 Range Rover Sport TDV8 HSE Galway Green
Hi folks,
Sorry to bring this one back to life but, does anyone have all the wiring diragrams for a facelift please.
Many thanks
Craig 2010 RRS 3.6 TDV8 HSE Galway Green
Post #632959 Tue May 09 2023 10:48am
That's a awful lot of diagrams, nearly 300 pages in total for the facelift, although a lot will be the same for both the MY10/11 and later MY12/13. I think the main differences will be the Infotainment circuits/interface. Did you want anything specific?
Post #632979 Tue May 09 2023 11:21pm
Jabba
Hi Col, sorry I totally forgot to look at the RRSL320WSM2006.pdf file for the wiring diagrams Banging Head I'm currently looking into my forward alert sensor issue and wanted to check the diagram prior to physically looking at the RRS.
Would there be much of a difference using these diagrams comparing to the facelift ones ?
Many thanks
Post #632981 Wed May 10 2023 6:24am
If it isn't working by any chance, are you sure it isn't turned off in the set up menu.
Post #632982 Wed May 10 2023 6:39am
Jabba
its a strange one, if I activate it in the menu, near enough every trip using crusie control I'll get a warning that there is an issue with the forward sensor and it kills cruise until I cycle the ignition. If I don't activate it and use cruise, I then get the same fault but not on every journey using cruise. The errors are (taken from an older scan):
CCM-Cruise Control
C1A67-96 - Forward looking sensor - Component failure - internal failure (28 )
( on 25-03-2023 18:49:59 at 86620 mi )
U0401-81 - Invalid data received from engine control module/powertrain control module - Bus signal/message failure - invalid serial data received (28 )
( on 25-03-2023 18:50:00 at 86620 mi )
Many thanks
Post #632983 Wed May 10 2023 6:51am
I don't know for certain, but I'm inclined to think that one code is causing the other, the radar modules are in a different position between the 05/09 and 10/13 cars, I also think I would be reluctant to assume the earlier vehicle wiring is the same as the later cars but it is a possibility. I assume the module wiring will come under the speed control section of the diagrams but not totally sure, I do have some diagrams here and will have a look to see what I can find.
Post #632984 Wed May 10 2023 7:31am
