![]() | Home > In Car Electronics > 2010 Facelift wiring diagrams |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9145 ![]() ![]() ![]() |
This is the manual for the 2013 L320. Does that help?
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5144 ![]() ![]() ![]() |
Try page 8.
Wafoo Member Since: 19 May 2020 Location: Pontypridd Posts: 36 ![]() ![]() ![]() |
It does for routing ![]() But no wiring diagrams,, ![]() |
It doesn't load mate |
Not sure why, it certainly does if I click on it myself, try this one.
Cheers Col, it works, it was my works computer didn't want to play, fine on my phone |
Probably security setting so you can't view naughty stuff. |
Jabba Member Since: 25 Jan 2023 Location: Norfolk Posts: 231 ![]() ![]() ![]() |
Hi folks,
That's a awful lot of diagrams, nearly 300 pages in total for the facelift, although a lot will be the same for both the MY10/11 and later MY12/13. I think the main differences will be the Infotainment circuits/interface. Did you want anything specific?
Hi Col, sorry I totally forgot to look at the RRSL320WSM2006.pdf file for the wiring diagrams |
If it isn't working by any chance, are you sure it isn't turned off in the set up menu.
its a strange one, if I activate it in the menu, near enough every trip using crusie control I'll get a warning that there is an issue with the forward sensor and it kills cruise until I cycle the ignition. If I don't activate it and use cruise, I then get the same fault but not on every journey using cruise. The errors are (taken from an older scan):
I don't know for certain, but I'm inclined to think that one code is causing the other, the radar modules are in a different position between the 05/09 and 10/13 cars, I also think I would be reluctant to assume the earlier vehicle wiring is the same as the later cars but it is a possibility. I assume the module wiring will come under the speed control section of the diagrams but not totally sure, I do have some diagrams here and will have a look to see what I can find.
