![]() | Home > Technical > suspension will raise when system cooled |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2024 ![]() ![]() |
Rusty hole in reservoir tank? * Current: 2024 D350 Defender 90 on coils!
markg103 Member Since: 06 Apr 2020 Location: cambridge Posts: 35 ![]() ![]() ![]() |
Many thanks DrRob i will look into it
Hi all , Need some help please, I have changed the compressor, reservoir block valve, front block valve, and the reservoir and its still the same, the pump does not kick in and there are no fault codes coming up anyone had the same issues and find a fault.
Considering the compressor doesn't run at all, have you tested it and checked it is getting power?
Hi Kev , yes I've got an auto electrician coming round tomorrow to take a look, I was wondering if anyone else had a similar problem or if its a common problem.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5134 ![]() ![]() ![]() |
probably the temperature sensor. (it has 2)
Hi Andy thanks for the reply where is the sensor located.
in the compressor somewhere.
