Home > Technical > suspension will raise when system cooled |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2007 |
Rusty hole in reservoir tank? Visitor from fullfatrr.com
Mon Dec 28 2020 12:54pm |
markg103 Member Since: 06 Apr 2020 Location: cambridge Posts: 35 |
Many thanks DrRob i will look into it
Mon Dec 28 2020 1:27pm |
Hi all , Need some help please, I have changed the compressor, reservoir block valve, front block valve, and the reservoir and its still the same, the pump does not kick in and there are no fault codes coming up anyone had the same issues and find a fault.
Thu Jan 14 2021 11:42am |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1138 |
Considering the compressor doesn't run at all, have you tested it and checked it is getting power?
Thu Jan 14 2021 11:58am |
Hi Kev , yes I've got an auto electrician coming round tomorrow to take a look, I was wondering if anyone else had a similar problem or if its a common problem.
Thu Jan 14 2021 12:14pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4779 |
probably the temperature sensor. (it has 2)
Thu Jan 14 2021 1:33pm |
Hi Andy thanks for the reply where is the sensor located.
Thu Jan 14 2021 5:14pm |
in the compressor somewhere.
Thu Jan 14 2021 6:46pm |
