![]() | Home > General (L494) > 2015 RRS - any way to get larger MPH display? |
Ash3 Member Since: 31 Aug 2019 Location: London Posts: 279 ![]() ![]() |
Not that I have seen.
pjbracer1 Member Since: 25 Aug 2014 Location: Southampton Posts: 413 ![]() ![]() |
I might be possible using the gap Tool as you can change the intrument panel skin design, there are quite a few so it would just be a matter of selecting on and trying it I guess, (only downside it the starting and restarting of the car when changing the CCF files. (Sorry if this sounds jiberish to anyone who doesnt have the Gap diagnostic tool)
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1210 ![]() ![]() ![]() |
I haven't seen this option in my Gap tool - is that something special you have to order from them? --
No I dont think so you have to load int he CCF files and i think its called skin design or layout, Ill take a screenshot and post back a bit later as im fitting something to the car a bit later on.
It might be possible as this is form the 2017 model and not the left hand side has much bigger MPH numbers
asnook Member Since: 11 Jan 2021 Location: Sussex Posts: 3 ![]() ![]() |
That looks quite promising, I have no idea what the Gap tool or CCF files are but the fact there's something out there that might do the job gives some hope. That large mph display in the middle of the speedo would be a lot better.
Thanks pjbracer1 for the PM and the details from your other post - all very helpful indeed, good stuff.
Just had a try at this, but nothing in the CCF for the Instrument Pack (or anywhere else).
Looks like some of the recent updates may have changed some of the menu's
My Gap tool is also on the Beta version, but that Fuel Gauge CCF is not there either.
Maybe, has your device been given access to the full CCF file list? Mine has as I needed it to enable a couple of things to play around with key programming mine is veriosn 3.1.4 build 20 on the app and my buld is 2753
Not sure, I have the 'standard' Beta version that I updated via the IID app (Windows).
yeah might be worth asking Pat if they have changed anything as there definitely was those 2 options for skin design and one of them had lots of design 01 and 02 and 03 etc.... I just set mine to design 2
if I go into CCF, I see a 'Confirmed List':
