![]() | Home > Maintenance & Modifications > Gear box oil change or flush? |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 959 ![]() ![]() ![]() |
Go for a flush everytime, it's the only way to actually change all of the oil. Empty and refill only does a percentage of the total amount. 2010 RRS, TDV8
Others have had a flush and the change afterwards is sublime, just when you thought it was good anyway. I had mine done which I thought was smooth. I had the oldest car but the lowest mileage and mine was filthy. 2006 2.7 TDV6 HSE in Cairns Blue. |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2018 ![]() ![]() |
Got for a Megaflush and use Bodsy who is mobile out of Telford so comes to you.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9128 ![]() ![]() ![]() |
The reason for the flush is that the majority of the gearbox oil is in the torque converter. This isn't emptied when you take the drain plug out so you only replace a proportion of the oil by doing that. That's the reason why the official oil change is actually a double change - empty via the plug, refill, run, repeat. This still doesn't change all of the oil, it just dilutes the old stuff with new.
Grey Member Since: 29 Nov 2020 Location: Bury St Edmunds Posts: 5 ![]() ![]() ![]() |
This 110% gearbox will be fine if flush done Correctly. |
Wayne - it was my L322 that I had Megaflushed by Bodsy not the Sport |
nobby Member Since: 02 Mar 2016 Location: Malvern Posts: 33 ![]() ![]() ![]() |
FLUSH |
I had it flushed at around 70k miles because I know that you take absolutely no care of your vehicles ![]() ![]() I was trying to remember how long ago I bought the Sport from you. Is it 4 years now? I know you hadn't had it flushed because we talked about it at the time. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Probably about 4 years and yes, I abuse every vehicle I own and never over maintain it |
Nilrem280 Member Since: 02 Jun 2020 Location: Portchester Posts: 84 ![]() ![]() ![]() |
I've been looking in to this for a while and been quoted anywhere between £360-£600 for a Megaflush.
Lhard92 Member Since: 31 Dec 2020 Location: Bristol Posts: 21 ![]() ![]() ![]() |
Just to follow on from this thread, if anyone can help advise me.
The 2010-2011 (6 speed) models are the easiest to perform a flush at home if you are a DIYer.
Kev, don't fancy doing mine do you 28.0c here at the moment and no lockdown either. |
