Home > Technical > Webasto heater advice
Demaske1
United Kingdom 2009 Range Rover Sport TDV8 HSE Arctic Frost
Hi once again. I am stlii getting used to my sdv6 black edition rrs sport. I have found that when I have the engine running from cold and cabin temptrature set at say 24 degrees the webasto is running. If I turn the cabin heater off the webasto goes off. I have turned off the timers on the dash so I know it’s not that but does the webasto come on until the car is up to the desired temperature ? My thinking is the webasto just helps the car get up to temperature quicker rather 5han a conventional heater or am I thinking incorrectly. Can’t figure out any other reason.i presume in hot weather or when the car is at normal temperature the webasto one’s not come on. Ami I right or not ?
Post #606883 Sun Nov 22 2020 2:52pm
riverblanche
Hi
your right the FBH is there to help the cars coolant get up to temprature not the cars interior heating
it can fire up on and off during slow stop start traffic as the engine needs it
Thumbs Up Porsche Cayenne 2022
gone Porsche Cayenne 2020
gone Corris Grey HSE Dynamic 2016
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #606885 Sun Nov 22 2020 6:04pm
Devon Z
England 2005 Range Rover Sport TDV6 HSE Java Black
Mine only kicks in on startup if the ambient temperature is below 5 degrees as per handbook. Steve
2005 2.7 TDV6 HSE, ongoing project.
1998 Volvo V70 R auto FWD, mothballed future project.
1999 BMW Z3 (owned from new) garage queen.
Post #606887 Sun Nov 22 2020 8:25pm
Demaske1
Webasto
Hi, I thought that was the case but when I turn the blowers off to the cab the webasto goes off and when I turn the blowers on it comes on again. I had already left the engine running for 15 mins and temperature gauge was just over a quarter of the way from cold. I’m just checking this is the way it’s supposed to be.
Post #606888 Sun Nov 22 2020 9:13pm
Devon Z
I’ve never played with the fan switch when mines running to honest, got some cold weather coming though. Steve
Post #606889 Sun Nov 22 2020 9:24pm
riverblanche
dont know then Question Question
but
a diesel car on tick over does not create a lot of heat, maybe with internal heating on the engine needs the FBH on to help it and when you turn fans off there is enough engine heat that it does not need the FBH on Confused
As the weather and temp gets colder more peeps will start to see/hear the FBH come on, stop at the shops come back out and its on again.
take it for a good run get the engine warm turn the fans and car heat up to full and see if the FBH kicks it, I doubt it will
Post #606913 Mon Nov 23 2020 2:12pm
Dave B
The FBH on my Disco with the SDV6 engine will run when the engine is running until the operating temperature has stabilised at 'normal', whereas the FBH in my RRS with the TDV8 will shut down as soon as the gauge is halfway to 'normal'.
I don't know if this helps, but there it is.
Dave 2010 3.6 TDV8 HSE (Gone)
2011 Discovery 4 Commercial SDV6 (Gone)
1980 OBLIC 4.0ltr Range Rover (went a long time ago)
Post #606923 Mon Nov 23 2020 5:50pm
