![]() | Home > Technical > ACE leaking |
| Wafoo Member Since: 19 May 2020 Location: Pontypridd Posts: 36
Good shout, I'll mention it to them |
| the_wombat Member Since: 29 Oct 2020 Location: Huntingdon Posts: 64
Sorry to re-invigorate the post from June.
| Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1849
Depending on the year, I believe some vehicles have an outrigger you can remove. Mine being 2012 was fixed. Some have managed to work the pipes over the outrigger through the gap but I didn’t have the space, even after disassembling the new pipes assembly to individual pipes, removing the body bolt, loosening the body mounts and lifting the body. So I went down the route of stainless compression joints. I just made sure I numbered each end of the pipe so each half would match the correct other half. I also cleaned each pipe out after cutting to remove any swarf.
Cheers |
Actually, with some time on my hands today, I decided I would lift the body on one side per other posts here.
A bit more research today. I had stupidly thought that new valve block seals were only available as part of a new valve block, but they are available separately if a little expensive.
I did not find it easy getting the old seals out! Had the valve block in situ as the rear pipes are OK, but decided in the end to take the whole thing to bits.
| mgrover Member Since: 17 Oct 2019 Location: Leeds Posts: 393
i saw them the other day I think, i only saw them because the fuel tank was dropped though |
id say just remember to remove fuel relay. also if youve dropped tank see if your filter is in it. if so may as well replace it while your there.
Undo the 10mm nut holding that bracket to the chassis
Thanks Disco_Mikey
Don't touch the clamp, undo the bracket that the clamp is bolted to |
Makes sense.
| All times are GMT |
