Home > Technical > ace pump |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8841 |
Presumably you mean the ARB pipes? If the pipes fail and dump the oil from the system then you'll potentially damage the pump. This is engine driven so can't really be disabled at the side of the road.
Fri Aug 28 2020 10:57am |
mgrover Member Since: 17 Oct 2019 Location: Leeds Posts: 393 |
recently the systems just been a PITA. I replaced the front pipe, two months later one of the orings for the ram connection fails dumping out all its oil. after thats fixed i found a slow leak from the valve block plug, easily fixed but am worried on going a longer journey and being stranded somewhere tbh. |
Fri Aug 28 2020 11:04am |
Well it happened. Am up north and the ace fluid is low. Am in the middle of knowhere so can't really do much about it aside from drive 10-20 miles to the near garage to top it up. Its on red warning so I guess no way to get away with it. Hopefully the top up will last the drive home about 150 miles |
Tue Oct 20 2020 8:28pm |
Flyfisherman Member Since: 12 Sep 2020 Location: Staffordshire Posts: 91 |
Just pull over if empties again and have it towed to usual garage that works on your car. |
Tue Oct 20 2020 9:09pm |
not really got that option atm, am like 150 miles away from that garage if i make to a garage maybe they can fit the non-ace auxiliery belt but we'll see. i think its a slow leak anyways so hopefully a simple top up will do. am kicking myself cause i was thinking huh should i bring spare fluid and thought nahhhh |
Wed Oct 21 2020 8:08am |
got some hydraulic CHF fluid. am told you need CHF11S thats equivalent but I couldn't find any 11S to go on top made the trip home fine topping up here and there.
Wed Oct 21 2020 12:57pm |
Glad to hear you managed to get home safely |
Wed Oct 21 2020 1:41pm |
thanks seems no ill effects from the lack of fluid to the pump yet. i did find a post that when it basically all goes to the bars go in locked mode. and the fluid goes back to the reservoir, so hopefully that means the pump has enough fluid to keep it lubricated.
Wed Oct 21 2020 2:11pm |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1138 |
Edited: sorry, pointless post after rereading the above! Kev
Thu Oct 22 2020 12:11am |
ah its fine. i was wondering if you had any thoughts on the pump. as long as a small amount of fluid circulates the system, will it be safe? |
Thu Oct 22 2020 6:47am |
That's a difficult one. If it were me, I wouldn't run it, but I appreciate the predicament you are in being a long way from home. Kev
Thu Oct 22 2020 7:23pm |
I mean thankfully its sorted now and I seem to of gotten away with it. but I think I'll defo be carrying a spare non SC belt just in case. |
Thu Oct 22 2020 10:07pm |
JonoRRS Member Since: 17 Sep 2020 Location: Wellington Posts: 6 |
I'd welcome any other views on whether the vehicle can br driven with no fluid in the system due to a broken hose. The Land Rover dealer said yes but then added "for short distances" which does not give me much confidence ... parts are on backorder and at least a month away 😠|
Tue Oct 12 2021 9:06am |
get a non sc belt and bypass the pump. cheapest option by far.
Tue Oct 12 2021 9:50am |
