![]() | Home > Technical > ace pump |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9139 ![]() ![]() ![]() |
Presumably you mean the ARB pipes? If the pipes fail and dump the oil from the system then you'll potentially damage the pump. This is engine driven so can't really be disabled at the side of the road.
mgrover Member Since: 17 Oct 2019 Location: Leeds Posts: 393 ![]() ![]() ![]() |
recently the systems just been a PITA. I replaced the front pipe, two months later one of the orings for the ram connection fails dumping out all its oil. after thats fixed i found a slow leak from the valve block plug, easily fixed but am worried on going a longer journey and being stranded somewhere tbh. |
Well it happened. Am up north and the ace fluid is low. Am in the middle of knowhere so can't really do much about it aside from drive 10-20 miles to the near garage to top it up. Its on red warning so I guess no way to get away with it. Hopefully the top up will last the drive home about 150 miles |
Flyfisherman Member Since: 12 Sep 2020 Location: Staffordshire Posts: 91 ![]() ![]() ![]() |
Just pull over if empties again and have it towed to usual garage that works on your car. |
not really got that option atm, am like 150 miles away from that garage |
got some hydraulic CHF fluid. am told you need CHF11S thats equivalent but I couldn't find any 11S to go on top |
Glad to hear you managed to get home safely |
thanks
Edited: sorry, pointless post after rereading the above! Kev
ah its fine. i was wondering if you had any thoughts on the pump. as long as a small amount of fluid circulates the system, will it be safe? |
That's a difficult one. If it were me, I wouldn't run it, but I appreciate the predicament you are in being a long way from home. Kev
I mean thankfully its sorted now and I seem to of gotten away with it. but I think I'll defo be carrying a spare non SC belt just in case. |
JonoRRS Member Since: 17 Sep 2020 Location: Wellington Posts: 6 ![]() ![]() ![]() |
I'd welcome any other views on whether the vehicle can br driven with no fluid in the system due to a broken hose. The Land Rover dealer said yes but then added "for short distances" which does not give me much confidence ... parts are on backorder and at least a month away 😠|
get a non sc belt and bypass the pump. cheapest option by far.
