![]() | Home > Technical > where to place front end Axle Stands |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9110 ![]() ![]() ![]() |
The place to put the stands is the same place that you put the jack. I'd strongly suggest you get a bottle jack or a trolley jack and avoid using the emergency jack provided with the vehicle. It's not very good and has been known to fail. If you're doing these types of project DIY, a trolley jack really is a must. You can then jack the front end up on the front subframe in one go and put the stands under chassis rails at the jacking points.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5115 ![]() ![]() ![]() |
there are 2 gurders that run along the car. They are about 12" in. Use these.
kenpassey Member Since: 03 May 2018 Location: Liverpool Posts: 33 ![]() ![]() ![]() |
Thanks, yes the supplied jack must be the worst one ive ever seen, i have 2 small trolly jacks which i will use as well, cheers |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 402 ![]() ![]() |
Hopefully not one on top of hte other ![]() |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 783 ![]() ![]() ![]() |
Most of us bite the bullet and buy a high lift trolley jack, something like this;
