![]() | Home > General > Front end rattle noise developing |
abiopete Member Since: 27 Feb 2020 Location: Manchester, UK Posts: 184 ![]() ![]() ![]() |
Hi All
Perhaps you’ve got some bushes that are excessively worn. You may be able to see cracked rubber underneath if it’s that bad. 2006 2.7 TDV6 HSE in Cairns Blue. |
Not dismissing it but it sounds more like a metallic rattle noise and only kicks in around the 2000rmp mark. |
Also its definitely only under load, engine purrs in neutral. L494 3.0L SDV6 Autobiography MY20 in Eiger Grey (Current)
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 783 ![]() ![]() ![]() |
I had a rattle from my front end, but heard not felt. It was the metal dust shield behind the front disc which was loose.
