Home > General > Front end rattle noise developing
abiopete
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Firenze Red
Hi All
As the title says, can hear/feel a rattle coming through the floor and steering wheel from the front of the car at around 1900 - 2100 rpm, any suggestions on where to start looking? I've had all the oils changed in the last 6 months (engine oil twice), with the front diff and megaflush being the most recent during lockdown.
67k miles on the clock.
TIA, Pete. L494 3.0L SDV6 Autobiography in Chile Red (Current)
L320 3.0L SDV6 Autobiography in Baltic Blue (RIP 29/03/2021 insurance total loss)
Post #605000 Mon Sep 28 2020 2:26pm
Stevepd
Perhaps you’ve got some bushes that are excessively worn. You may be able to see cracked rubber underneath if it’s that bad. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #605004 Mon Sep 28 2020 4:37pm
Stevepd
Post #605005 Mon Sep 28 2020 4:43pm
abiopete
Not dismissing it but it sounds more like a metallic rattle noise and only kicks in around the 2000rmp mark. Thumbs Up L494 3.0L SDV6 Autobiography in Chile Red (Current)
Post #605006 Mon Sep 28 2020 4:44pm
abiopete
Also its definitely only under load, engine purrs in neutral. L494 3.0L SDV6 Autobiography in Chile Red (Current)
Post #605030 Tue Sep 29 2020 1:47pm
Oldandconfused
I had a rattle from my front end, but heard not felt. It was the metal dust shield behind the front disc which was loose.
It may be worth a check as it's a cheap fix (fingers crossed for you).
Post #605039 Tue Sep 29 2020 7:22pm
