| RRSPORT.CO.UK | ||
|  | Home > Maintenance & Modifications > Replacing rear discs |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145      | Well at the very least there will be a lip on inside of the drum.
|  Wed Sep 23 2020 11:33am |
| dangermousehouse Member Since: 01 May 2009 Location: Cairns Posts: 32    | Thanks Andy.
|  Wed Sep 23 2020 11:54am |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145      | I know it sounds odd, but you will get a lip on a used disc.
|  Wed Sep 23 2020 11:56am |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156      | Strangely enough just in the process of changing my MY13 rear discs and park brake shoes etc. followed Bodsys Brake Bible to the letter and it was spot on, just backed the adjuster right off through the hole in the disc, quick smack with a dead blow hammer and disc dropped straight off, only small lip on the drum bit and think that is mainly rust scale not wear. The pain bit looks to be the "bedding in" process for the new shoes/discs. The park brake will not engage automatically when switching ignition off unless it has been activated that way in the CCF files, but if you remove the EBC fuse in the engine bay fuse box it isolates it anyway.
|  Wed Sep 23 2020 8:33pm |
| knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139      | When I replaced my rear discs, I remember I had to back off the adjuster. I also followed Bodsy's bible and it was spot on   | ||
|  Wed Sep 23 2020 10:41pm |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156      | Kev, how did you get on bedding the shoes in as suggests need to do that even if you fit just new discs, or did you not really bother? and just settle for the adjustment.
|  Wed Sep 23 2020 11:15pm |
| dangermousehouse Member Since: 01 May 2009 Location: Cairns Posts: 32    | Thanks for replies.
|  Thu Sep 24 2020 12:24am |
| garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1071    | In the normal operating position the brake shoes are right up on the drum to ensure full activation when applied - this may mean the shoes can touch the drum causing wear.  Likewise dirt in the drum will grind away at the drum causing wear.  Likewise using the drive through function to release the park brake will cause wear as the auto brake release function has a little lag with the vehicle attempting to move before the brake being fully released.
|  Thu Sep 24 2020 12:40am |
| dangermousehouse Member Since: 01 May 2009 Location: Cairns Posts: 32    | Thanks for that.
|  Thu Sep 24 2020 5:32am |
 Hi Col, I didn't replace the shoes as they were fine. i just gave the whole disc and the inside of the drum a good clean then set the knurled adjuster as per the bible. Kev MY2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey MY2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey | ||
|  Thu Sep 24 2020 6:32am |
| Louis356 Member Since: 29 Dec 2019 Location: Milton Keynes Posts: 7      | Where can I find "Bodsys Brake Bible"
|  Thu Sep 24 2020 1:06pm |
| knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139      | https://media.disco3.co.uk/gallery/albums/...1.4sml.pdf Kev
|  Thu Sep 24 2020 1:11pm |
| Louis356 Member Since: 29 Dec 2019 Location: Milton Keynes Posts: 7      | Thanks | ||
| Posting Rules
