Home > Maintenance & Modifications > Replacing rear discs
dangermousehouse
Australia
Just wondering if someone could straighten me out, please?
I'm going to change the rear discs on our 2012 TDV6. I've watched a few youtube videos and had a read of the brake bible.
But, I'm confused with EPB. Instructions show releasing the EPB using a screwdriver and manipulating the ratchet, to allow for getting the disc off.
Why would I need to do this, if I didn't engage the EPB in the first place? (we very rarely use it, just rely on the gearbox Park)
Am I missing something? Less is more, more or less
Post #604809 Wed Sep 23 2020 11:53am
Well at the very least there will be a lip on inside of the drum.
If you were to try to pull it off, the shoes would catch on this.
Same applies if you don't have EPB.
It's to create extra clearance
Post #604810 Wed Sep 23 2020 12:33pm
dangermousehouse
Australia
Thanks Andy.
Why would there be a lip? I can't quite see how there would be wear on the pads or disc as it's a park brake.
Does the park brake automatically engage when the ignition is off? Less is more, more or less
Post #604811 Wed Sep 23 2020 12:54pm
I know it sounds odd, but you will get a lip on a used disc.
manual Disco's can automatically engage the EPB at key removal.
Post #604812 Wed Sep 23 2020 12:56pm
Strangely enough just in the process of changing my MY13 rear discs and park brake shoes etc. followed Bodsys Brake Bible to the letter and it was spot on, just backed the adjuster right off through the hole in the disc, quick smack with a dead blow hammer and disc dropped straight off, only small lip on the drum bit and think that is mainly rust scale not wear. The pain bit looks to be the "bedding in" process for the new shoes/discs. The park brake will not engage automatically when switching ignition off unless it has been activated that way in the CCF files, but if you remove the EBC fuse in the engine bay fuse box it isolates it anyway.
Post #604824 Wed Sep 23 2020 9:33pm
knwatkins
When I replaced my rear discs, I remember I had to back off the adjuster. I also followed Bodsy's bible and it was spot on Thumbs Up Kev
Post #604828 Wed Sep 23 2020 11:41pm
Kev, how did you get on bedding the shoes in as suggests need to do that even if you fit just new discs, or did you not really bother? and just settle for the adjustment.
Post #604831 Thu Sep 24 2020 12:15am
dangermousehouse
Australia
Thanks for replies.
I guess what's confusing me is when the instructions show turning the hub to line the ratchet hole up, surely the EPB is off to allow the hub to be turned, so why wind the ratchet off?
The lip on the inside of the drum answers that, I guess. Less is more, more or less
Post #604833 Thu Sep 24 2020 1:24am
garrycol
Australia
In the normal operating position the brake shoes are right up on the drum to ensure full activation when applied - this may mean the shoes can touch the drum causing wear. Likewise dirt in the drum will grind away at the drum causing wear. Likewise using the drive through function to release the park brake will cause wear as the auto brake release function has a little lag with the vehicle attempting to move before the brake being fully released.
This can all cause wear of the drum which the shoes account for - it may develop a lip and make the drum hard to get off but in my view the issue is when you put a new drum on that it has no wear (or you put new shoes on as they wear) and the shoes' adjustment needs to be done - not something you want top do with the drum off .
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #604834 Thu Sep 24 2020 1:40am
dangermousehouse
Australia
Thanks for that.
Mind is at rest Very Happy Less is more, more or less
Post #604835 Thu Sep 24 2020 6:32am
knwatkins
Hi Col, I didn't replace the shoes as they were fine. i just gave the whole disc and the inside of the drum a good clean then set the knurled adjuster as per the bible. Kev
Post #604836 Thu Sep 24 2020 7:32am
Louis356
United Kingdom 2007 Range Rover Sport TDV6 HSE Bonatti Grey
Where can I find "Bodsys Brake Bible"
I need to do mine soon?
Post #604857 Thu Sep 24 2020 2:06pm
knwatkins
https://media.disco3.co.uk/gallery/albums/...1.4sml.pdf Kev
Post #604858 Thu Sep 24 2020 2:11pm
Louis356
Thanks
Post #604859 Thu Sep 24 2020 2:11pm
