Home > In Car Electronics > New Android 9 Discovery/RRS Android Stereo System |
mrluke Member Since: 22 Apr 2018 Location: Essex Posts: 270 |
Ok after testing more in the car i noticed satnav sound stopped working (it was working on the bench randomly)
Thu Oct 15 2020 6:18pm |
Ok after testing more .
Wed Oct 28 2020 8:49am |
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 |
Great to hear you have got the system finally working as it should.
Sat Nov 14 2020 6:09am |
Hey ,
Wed Nov 18 2020 9:48am |
Cheers,
Thu Nov 19 2020 9:59am |
luckly downsizing the memory stick solved the issue , the 32gB one i was using has a problem i believe as it was disconnecting from the pc.
Sat Nov 21 2020 9:04am |
SUGO Member Since: 29 Dec 2020 Location: NOVARA Posts: 1 |
Hello! Same problem on my RRS "Zuolv" 10.25 unit ! What do you mean with "Remove pin 4 to pin 5 hole" ??? Another question: when I press voice command button on steering wheel it starts both Oem assistant and google assistant together, and one speak with the other aaaaargghhhhh, do you have the same problem? |
Tue Dec 29 2020 1:13am |
Hey , Sorry missed this response
Mon Jan 18 2021 9:15am |
For any one still interested in this unit. I have been using it quite a bit and it works fine now since the seller sorted out the problems.
Mon Mar 01 2021 10:07am |
