![]() | Home > In Car Electronics > Steering wheel upgrade |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5087 ![]() ![]() ![]() |
Why would you want to do that? the conversion works perfectly well including Paddle Shift and Acc with the Can Bus system. The reason I ask is I did this conversion years back and don't re-call changing anything in the CCF files. I also thought although they run along side each other the Can Bus system was better than the Lin Bus at least for certain circuits but could well be totally wrong on that one.
There is a guy on facebook that is doing the boards at a fraction of the price blackbox charge and the over on Disco3 seem happy with them try searching over there |
Ians63 Member Since: 03 Sep 2019 Location: NE Scotland Posts: 20 ![]() ![]() ![]() |
Search for Fritjof Dittner on Facebook and contact him through messenger. As already said far cheaper than BBS. RRS 2006
Hi
hogster Member Since: 11 Feb 2020 Location: Ireland Posts: 11 ![]() ![]() ![]() |
I have ordered a 2012 spec heated steering wheel and spent hours reading up on this. I need to get the clock spring and the electronics. I was going to use black box but interested to hear theres someone else offering this.
mgrover Member Since: 17 Oct 2019 Location: Leeds Posts: 393 ![]() ![]() ![]() |
if i understood your post correctly does that mean we can retrofit a heated steering wheel on a first gen L320? |
Yes, if you search "heated steering wheel" are plenty of posts on the subject.
Yea the facelift 2010-2013 RRS steering wheel can be installed to the older 2005-2009 preface but requires a few bits to do it. Its a job I am tackling soon. |
ive got an eye on a steering wheel. ill order it tonight.
Make sure you get the right clock spring there is only one that will do the heated wheel. LR018556
if the steering wheel is a heated one anyways will it not come with a heated clock spring? |
No, it's a seperate item unless who ever is selling the wheel is selling one with it.
fair enough ill make sure to ask. thanks |
So the clockspring should be the following:
