![]() | Home > General > TDV8 Terminal Battery Drain |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 959 ![]() ![]() ![]() |
How old is the battery??. You say you've done a basic test??,, I'm guessing charging voltage and standing voltage. You should be seeing 14.6V or thereabouts at idle and at rest a fully charged battery would be 12.6V. If you are seeing low 12's at rest I would suspect the battery. Only way to tell is to have a proper test put on it,, it could well be the battery is not holding its full capacity,, I have had this before,, catching me out with the odd flat battery but would run ok once jumped. These cars need a good reliable battery to run properly,, you could try charging it overnight to see if it improves as a quick run round the block will not charge the battery. 2010 RRS, TDV8
Staftly Member Since: 26 Mar 2013 Location: Lancashire Posts: 5 ![]() |
Hi Gogsy1956
Hi Gogsy1956
Aye,,give it a decent charge overnight and check your voltages. If you have a 2 piece tailgate the latch on the upper section is renowned for problems,, like letting in water etc whixh is worth looking at for minimal cost. 2010 RRS, TDV8
If the battery is a calcium battery then it will be beyond recovery and the only cure is to buy a new one. After going through 3 batteries in 18 months I’ve binned off the Ca batteries and fitted an AGM.
If the battery has been changed like for like it'll probably be a lead acid as the original battery would have been wet cell as mine was. I've also been caught out having charged my battery with a ctek but still finding it would go flat if I left the radio or TV on for 5 mins. This problem is down to the battery having a reduced current carrying capacity ( amps),,, this is what you need to start a car, especially something the size of a Rangie. 2010 RRS, TDV8
