| RRSPORT.CO.UK | ||
|  | Home > General > TDV8 Terminal Battery Drain |
| gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 961      | How old is the battery??.  You say you've done a basic test??,,  I'm guessing charging voltage and standing voltage. You should be seeing 14.6V or thereabouts at idle and at rest a fully charged battery would be 12.6V. If you are seeing low 12's at rest I would suspect the battery. Only way to tell is to have a proper test put on it,, it could well be the battery is not holding its full capacity,, I have had this before,, catching me out with the odd flat battery but would run ok once jumped. These cars need a good reliable battery to run properly,, you could try charging it overnight to see if it improves as a quick run round the block will not charge the battery. 2010 RRS, TDV8
|  Sat Aug 22 2020 12:31pm |
| Staftly Member Since: 25 Mar 2013 Location: Lancashire Posts: 5  | Hi Gogsy1956
|  Sun Aug 23 2020 2:56pm |
|  Sun Aug 23 2020 2:57pm |
| gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 961      | Aye,,give it a decent charge overnight and check your voltages. If you have a 2 piece tailgate the latch on the upper section is renowned for problems,,  like letting in water etc whixh is worth looking at for minimal cost. 2010 RRS, TDV8
|  Sun Aug 23 2020 6:51pm |
| Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1849      | If the battery is a calcium battery then it will be beyond recovery and the only cure is to buy a new one. After going through 3 batteries in 18 months I’ve binned off the Ca batteries and fitted an AGM.
|  Mon Aug 24 2020 12:21pm |
| gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 961      | If the battery has been changed like for like it'll probably be a lead acid as the original battery would have been wet cell as mine was. I've also been caught out having charged my battery with a ctek but still finding it would go flat if I left the radio or TV on for 5 mins. This problem is down to the battery having a reduced current carrying capacity ( amps),,, this is what you need to start a car, especially something the size of a Rangie. 2010 RRS, TDV8
|  Mon Aug 24 2020 4:31pm |
| Posting Rules
