Home > Maintenance & Modifications > ACE /Dynamic Reponse Leak 😔
Tilz
Hi all
First ever post, so go easy on me please! I recently purchased a 2006 Range Rover Sport 4.2 SC. I absolutely love the car, but there are so many issues cropping up now. The biggest concern is the ACE bar. Its leaking HEAVILY. I have to top up the dynamic fluid literally every few hours if I want to drive and not have the red suspension warning (goes away if i top up fluid).
I’ve last topped up with Smith and Allan cold climate and the leak has started, surely it can’t be the fluid?
Anyway i crawled under the car today and think I’ve found the cause, not any pipes or hoses. It seems to be the unit itself that’s not sealed shut?. Can I seal this with metal sealant/ epoxy?
See pics below. Sinking feeling here that this car will drive me crazy.
Post #603518 Thu Aug 20 2020 9:54pm
knwatkins
Is it me, or does the outer casing look distorted?
Active ARB leaks are a common point of failure on the L320. Some have performed some temporary fixes using power steering stop-leak fluids with success. Note use of the word 'temporary' because the sensible advice is to always fix the issue properly and replace. Kev
Post #603520 Thu Aug 20 2020 10:15pm
You can't seal it as it's a hydraulic ram - it moves in and out a bit as it works. 2012 SDV6 - it's missing a couple of cylinders
Post #603522 Thu Aug 20 2020 10:22pm
Unfortunately looking at the outer casing of the ram those "indentation" around the circumference indicate to me the end cap is crimped in so it is not possible to remove it to replace the seals without re-engineering, assuming you could even get replacement seals. Conventional rams those caps are/were screwed in and when I worked with heavy construction equipment we were for ever resealing hydraulic rams, fitting new piston rods etc. So at L/R prices that will be £1500.00 please, thank you very much Sir.
Post #603524 Thu Aug 20 2020 10:37pm
knwatkins
From the pictures, I think it's leaking from between the end cap and the casing, not the moving piston. I could be wrong though! Kev
Post #603525 Thu Aug 20 2020 11:03pm
DrRob
Moore Automotive Ltd in Chertsey
Rovertune in Reading
Vogue Autos in South Ruislip (heard about them but can't vouch)
Dartford Transmissions and Autocare - Martin Hind (top lad)
Thumbs Up * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
I use www.glenrands.co.uk Great independent
Post #603532 Fri Aug 21 2020 8:12am
aaronjb
I see what you mean - it looks like the end cap is no longer perpendicular to the plane of the bottom of the outer barrel, like it has twisted slightly.
Maybe failed ARB bushes allowing the bar ends to try and 'articulate' their way out of the hydraulic unit? 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #603537 Fri Aug 21 2020 8:58am
mgrover
If you need to replace the bar it's a body off job. Id check the pipes supplying the bar and if they aren't in great nick get them replaced at same time body is off
Post #603539 Fri Aug 21 2020 9:12am
Tilz
Took the plunge and bought a new ARB from Advanced factors.
Post #603559 Fri Aug 21 2020 2:59pm
Which is why going to someone like Advanced Factors makes sense. About £600 for the front ARB, £700 for the rear one. That's incl the VAT.
Still a non-cheap job, but it's not quite as eye watering as LR's extortionate pricing. 2012 SDV6 - it's missing a couple of cylinders
Post #603560 Fri Aug 21 2020 2:59pm
The right thing to do. These things never really "mend" properly so replacing means that at least you'll have that part out of your mind for a good while onwards. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #603561 Fri Aug 21 2020 3:00pm
knwatkins
^^^ Agreed. Do it once and do it properly.
You replaced your front ARB on your TDV8 yourself didn't you, Wayne? Kev
Post #603565 Fri Aug 21 2020 3:56pm
Tilz
Yeah agreed. I’d otherwise always worry about it. Hopefully have it fitted next week. Steering felt heavy so hopefully this is the fix that was needed.
Next jobs are the fluid changes for the transmission, transfer case and diffs!
Post #603581 Fri Aug 21 2020 8:06pm
Good lord, no! I'm not set up to do stuff like that. I've had a rear one replaced before now but done by a garage. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #603591 Sat Aug 22 2020 7:53am
knwatkins
Ah fair enough. I don't know why I thought that Laughing Kev
Post #603603 Sat Aug 22 2020 12:41pm
