Home > Technical > Limited gears
Page 3 of 4 <1234>
DerrekL
Thumbs Up RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #603214 Wed Aug 12 2020 11:17pm
DerrekL
Front and rear prop shafts off
Transfer case off
Gearbox being supported for now
Next steps, something like this...
Take starter motor off ? This enables to access TC bolts ? Take the four TC bolts out
Unbolt all surrounding bellhousing bolts and surrounding brackets ?
Do I need to prise the gearbox from the bellhousing back the way or will it drop down right away ?
P38 4.6 HSE V8
Post #603259 Thu Aug 13 2020 10:11pm
Yeah
Remove plastic cap above the starter
Unbolt the exhaust cross over pipe bolts
Disconnect cooler fluid lines. 1 bolt
I assume you need to withdraw the gearbox
Post #603260 Thu Aug 13 2020 10:25pm
DerrekL
Contraption set-up to pull out and drop gearbox, the gearbox has came away from the engine by few inches, question is where should I support the engine about, I think I screwed up by not chalking up the engine first, how do I know the gearbox has actually safely cleared the engine, is there a spline sticking out the engine or gearbox ?
P38 4.6 HSE V8
Post #603341 Sun Aug 16 2020 10:14am
I think you need at least 6 inches gap.
I don’t know if the 4 bolts are what connects the drive or if there is a spline too.
Recommend you watch the bmw video
Some typos in your question so don’t fully understand.
Should be no need to support the engine
Post #603342 Sun Aug 16 2020 10:27am
DerrekL
Ok thanks Andy I'm just about to give it another go Thumbs Up RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #603343 Sun Aug 16 2020 11:11am
DerrekL
Gearbox is out now. It is a 500570 model, do I strictly have to swap like for like ? As I do see 500460 on other similar aged gearboxes, on eBay ?
Just asking but there is a bit of play in the shaft of the gearbox, I take it that’s not good? Should there be no wiggle room in these or should I expect minimal movement on any 2nd hand gearbox ?
P38 4.6 HSE V8
Post #603360 Sun Aug 16 2020 5:15pm
Well done Thumbs Up
I don’t know sorry Thud
Post #603365 Sun Aug 16 2020 6:27pm
DerrekL
Thanks Andy, was a relief to get it on the ground Rolling with laughter
Any idea if I need to program the car to any other replacement gearbox ?
P38 4.6 HSE V8
Post #603369 Sun Aug 16 2020 8:46pm
Yes. Can be done with iid and support from pat at gap
Post #603370 Sun Aug 16 2020 8:56pm
DerrekL
Superb thanks Andy Bow down RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #603373 Sun Aug 16 2020 10:12pm
DerrekL
Putting things back together now....
TC is now bolted to the flywheel.
Should I bolt the exhaust bracket to the gearbox first before fitting the gearbox or bolt the bracket to the exhaust then lift the gearbox up and fit.
You'll see from my question that I'm just trying to figure out the best way to put it all back together with the least hassle. As I know there is not much room up there, so if I can figure out the small things, then it should give me a better chance.
P38 4.6 HSE V8
Post #603655 Sun Aug 23 2020 6:30pm
Sorry. I’ve not done it before.
I think I would loosy bolt to the exhaust so it doesn’t get forgot
Don’t you need to align the Tc with the gearbox ? Not sure.
See if there is a location thing using the old Tc
Post #603656 Sun Aug 23 2020 6:37pm
DerrekL
Thanks Andy
Yes there's a female key/locator notched out the TC and a male key is located on the gearbox itself, hopefully that's what you mean ?
I was hoping that the gearbox would fit into the female locator on the TC when the gearbox is mated up to the bellhousing.
I had marked the position of the flywheel and bellhousing when the gearbox was dropped, my plan was to turn the flywheel back to this mark, good or bad idea ?
Is that what you mean by alignment ? And is there a very specific way it has to be done ?
P38 4.6 HSE V8
Post #603657 Sun Aug 23 2020 7:47pm
That’s fine. Sounds like you have it covered Thumbs Up
Post #603658 Sun Aug 23 2020 7:49pm
Page 3 of 4 <1234>
