![]() | Home > Technical > Limited gears |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5127 ![]() ![]() ![]() |
Well you need a replacement gearbox |
DerrekL Member Since: 23 Jul 2015 Location: West Lothian Posts: 240 ![]() ![]() ![]() |
Thanks for the feedback Andy |
Yeah it's probably the gearbox.
Nice one Andy thanks for that, might be something I could do.
I've not done it yet, so not a lot to add ATM |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9144 ![]() ![]() ![]() |
Sounds like the torque converter clutch is done for. That can be replaced as an item if you wish. The problem with buying a second hand gearbox is that it might be not far off being rubbish too. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Thanks Andy, if you find anything else, please let me know... |
Gearbox needs to come out to replace TC as it's in the middle between engine and gearbox
The TC clutch is within the TC housing so you get a new one when you replace the TC.
Superb!! short and to the point, just how it should be, thanks again guys |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4528 ![]() ![]() ![]() |
New gearbox time
You may as well use your existing transfer box as it’s known good.
Thanks for all the info guys, at least now I have an idea of what route to go down, and thanks for chipping in Mikey, much appreciated |
Ok plan is to drop the gearbox at least.
