Home > General > Autobox not staying in manual
sportgoogle
Towed the caravan today and tried to find best mpg using cruise control and manual mode in the auto gearbox.
But the gearbox would not stay in manual, kept going back into auto.
Is this right to happen ?? RRS HSE SDV6 2012
Post #602393 Tue Jul 28 2020 9:54pm
Do you mean you used the paddles to select a gear? And then it went back to "D" after a period of time? If so, yes, that's normal. 2012 SDV6 - it's missing a couple of cylinders
Post #602395 Tue Jul 28 2020 10:51pm
aaronjb
But if you stick it in Sport and then use the paddles, it stays in manual mode IIRC? Been a very long time since I used the paddles, though (also might be a <=2010 thing)? 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #602406 Wed Jul 29 2020 9:36am
Phil2k
United Kingdom 2012 Range Rover Sport SDV6 Autobiography Santorini Black
Mine is a 2013 and does the same
Post #602432 Wed Jul 29 2020 3:44pm
insiorc
Scotland 2013 Range Rover Sport SDV6 Autobiography Firenze Red
Yes if in sport mine will stay in manual, in D after somewhere around 10 seconds after last using the paddles it returns to auto. 13MY Range Rover Sport Autobiography SDV6 - mine
14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's
99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite
Post #602453 Wed Jul 29 2020 9:19pm
Brit Plumber
It will return to D if certain conditions are met.... but I can’t remember what they are. Mine will stay in manual if I’m not moving, no matter how long I wait. It also holds the gear if I’m changing throttle position as if readying for an overtake. If I don’t move the throttle it will return to normal quite quickly. You can also deselect manually by holding the Paddle back for 4 seconds??? 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #602525 Thu Jul 30 2020 9:45pm
aaronjb
This reminds me of the first time a friend drove my car - it was already in Sport mode and he was using the paddles when he uttered the words "Doesn't this thing have a Sport mode?"
"Er, you're already in it."
*look of intense disappointment*
Then he tried to throw it around a corner like he was driving his car ... a Gallardo.
I thought we were about to end up in the bushes! 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #602544 Fri Jul 31 2020 9:25am
