![]() | Home > General > Dead after starter replacment |
Earth strap |
| L111YDB Member Since: 14 Jul 2020 Location: West midlands Posts: 24
Where is the location.of that earth strap mate?
RH engine mount - front of suspension turret on chassis - body
I suppose that's a pain to get to aswell lol
Little update.
Put the starter back on
I could do with turning the engine a few cycles by hand to eliminat engine seizure 100% really I think .
Fairly common...
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5138
The starter won't run with it unbolted from the engine, as it isn't earthed.
Right .
| david007 Member Since: 20 Jun 2017 Location: Forfar Posts: 166
If you’ve not done so already I’d have a look on YouTube for how to test a starter motor, it’s quite easy to test them, you should be able to test both the stater motor and solenoid to see if you have a problem with either, with regard to the broken connector if you’ve got your old starter I’d test that also, depending with what’s wrong with that it might be possible to swop the solenoids over, I'm not sure from your description but I’m guessing the broken connector is on the solenoid. |
Have you snapped the ring terminal with the captive nut? |
No I've bost the bloody ring comnector on the lead . The lad who got his hands up there to get it back on said he needed to bend it so it was easier ......then snap.
| All times are GMT |
