Home > General > Dead after starter replacment
Page 1 of 4 1234>
L111YDB
United Kingdom 2009 Range Rover Sport 3.0 TDV6 Autobiography Zermatt Silver
Managed to change my dead starter motor on my 10 plate range rover sport 3.0v6
Still won't crank at all .
Checked and swpped relay under the bonnet
Checked the mega fuse
checked the connection onto the starter itself . Just incase .
Is there anything else I can check ? Because I'm bloody stumped now .
Any help gratefully recieved .
Post #601780 Wed Jul 15 2020 7:07pm
Well you need to get brave. Stick it in park.
Either
1) test small wire is + when cranking with a bulb
2) touch the small and big wires and see if it cranks ( will be a bit of sparking)
Post #601781 Wed Jul 15 2020 7:22pm
L111YDB
I'm gonna pop outside in a bit just to check the starter turns if I bridge it with a screwdriver .
Its really frustrating after the mission I had changing the starter in the first place
Thanks for your reply buddy and I will be in touch shortly with the results
Post #601783 Wed Jul 15 2020 7:29pm
L111YDB
Just tested the small wire and while cranking its live
Big wire is live also.
I did bridge it with a screwdriver and it clicks .
Got 12v showing on battery and when cranking now clicks as if battery is dead .
Any more things I can try .
I hae put the battery on charge just incase aswell but it was a brand new battery this week
Thanks
Post #601791 Wed Jul 15 2020 8:27pm
Does sound like battery
Post #601793 Wed Jul 15 2020 8:52pm
L111YDB
Took a battery off a pals v8 diesel and exactly the same.
He seems to think bad starter or engine seized ?
Is it common for these engines to seize just like that ?
Or even snap the crank ? He said it was common in the 2.7 apparently but I aint clued up.on these range rovers .
Post #601795 Wed Jul 15 2020 10:21pm
Put the transmission in park or neutral and see if you can turn the engine by hand, if engine is seized shouldn't be able to turn it over, if it turns probably not seized at least.
Post #601796 Wed Jul 15 2020 10:26pm
3.0 have similar probs to 2.7
Post #601798 Wed Jul 15 2020 10:52pm
L111YDB
Before work this morning I turned the viscous fan bolt which made the crank turn to the point it hit compression . But it turned a few times ..
I'm thinking I need to drop the starter back off and check that the flywheel turns when I do this .
So.many people putting things in my head about snapped cranks saying the front will turn but the read will be snapped and won't turn etc .
Hope it is just a dud starter to be honest
Post #601804 Thu Jul 16 2020 7:15am
Brit Plumber
I read this and after the first few post I thought, engine seized and likely snapped crank. Try as Col said and turn the engine, if not, pull the starter and with it connected, press the start button and see if it works. I fear the worst but hope for the best. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #601805 Thu Jul 16 2020 7:17am
L111YDB
I get off work at so ill get on with it then .
Fingers crossed it aint a snapped crank thats all I need .
I really hope the starter is a dud .
Cheers for taking time to reply lads .
Post #601807 Thu Jul 16 2020 8:08am
Brit Plumber
As a long shot, what battery is it and where was it from? Have a look on the label (usually on the back) and see if there’s a calendar on it showing when it needs a recharge and if that recharge has been done. That recharge date is for when it’s stored on the shelf before purchase and not after it’s been fitted. There’s a chance it may be new but flat after 6 months on the shelf. And if it’s been done late, it could be too late with batteries such as Calcium (Often branded as silver) being beyond recovery. 2019 5.0 SC SVA (Current)
Post #601817 Thu Jul 16 2020 10:52am
Brit Plumber
And please don’t tell me it’s a Halfords HSB019. 2019 5.0 SC SVA (Current)
Post #601818 Thu Jul 16 2020 10:52am
I think he's tried a different battery from another vehicle and still the same.
Post #601820 Thu Jul 16 2020 10:59am
Brit Plumber
Agh yes, just seen it.
The only other thing I’ve seen cause this that’s not a seized engine, dead starter or battery is a seized power steering pump. If all else fails test all the ancillaries turn (I see you can turn the fan but I don’t know what belts power what on the V6 2019 5.0 SC SVA (Current)
Post #601824 Thu Jul 16 2020 11:12am
Page 1 of 4 1234>
