Home > Maintenance & Modifications > Rear Door Speaker Grille
PeteF74
United Kingdom 2011 Range Rover Sport SDV6 HSE Lux Orkney Grey
Does anyone know if its possible to remove the speaker grille from the o/s/r door without having to take the whole door card off?? I don't want to prize anything off in case its not meant to be. Thanks.
Post #601232 Fri Jul 03 2020 4:07pm
Brit Plumber
You haven’t said the year but a 10 to 13 deffo can’t be. It is plastic riveted and hot melted in a number of places. 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
Remote Boot close from key fob
2016 Discovery 4 Mirrors AKA RRS2
2014 L405 Surround Camera retro fit (WIP)
2013 RRS Dual View Screen fit (Complete)
2016 LR4 RSE
2014 LR4 Homelink
2016 FFRR Electrochromatic Wing Mirror Glass
70 plate Focus ST (Current)
Post #601432 Wed Jul 08 2020 2:38pm
PeteF74
ah ok thanks for that. There is a slight crack in my speaker cover which isn't the end of the world but its a bit annoying on an otherwise spotless interior. A new door pad seems a bit extreme!
Post #601784 Wed Jul 15 2020 8:33pm
PeteF74
Its a 2011 by the way, so what you said applies to my car.
Post #601785 Wed Jul 15 2020 8:34pm
Brit Plumber
So when I said you can’t replace it, what I meant was, you can’t get a new replacement part. My rear right was cracked with a piece missing. I bought a replacement damaged door card with the correct colour grill which had no damage. I drilled off the plastic rivet heads and removed the grills. The tail is still in the post after drilling the heads off so I just pulled them out leaving a hollow post. I then bought some self tapping screws that were just bigger than the hole in the posts and appropriate washers. I had to grind some a bit shorter so they wouldn’t come through the front but it wasn’t a problem. You can’t tell and it looks good even on the inside. 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
2016 LR4 RSE
2014 LR4 Homelink
Post #601787 Wed Jul 15 2020 9:04pm
PeteF74
Thanks for that. Sounds like I need to find a salvaged card and strip that. I need a few parts now to get the car up to standard but on the whole its pretty good. I am just being very fussy.
Fixing the split on the side of the drivers seat base will be the next job!
Post #601850 Thu Jul 16 2020 4:18pm
