Home > Maintenance & Modifications > Rear Door Speaker Grille |
PeteF74 Member Since: 01 Jul 2020 Location: South Wales Posts: 83 |
Does anyone know if its possible to remove the speaker grille from the o/s/r door without having to take the whole door card off?? I don't want to prize anything off in case its not meant to be. Thanks. |
Fri Jul 03 2020 3:07pm |
ah ok thanks for that. There is a slight crack in my speaker cover which isn't the end of the world but its a bit annoying on an otherwise spotless interior. A new door pad seems a bit extreme! |
Wed Jul 15 2020 7:33pm |
Its a 2011 by the way, so what you said applies to my car. |
Wed Jul 15 2020 7:34pm |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1847 |
So when I said you can’t replace it, what I meant was, you can’t get a new replacement part. My rear right was cracked with a piece missing. I bought a replacement damaged door card with the correct colour grill which had no damage. I drilled off the plastic rivet heads and removed the grills. The tail is still in the post after drilling the heads off so I just pulled them out leaving a hollow post. I then bought some self tapping screws that were just bigger than the hole in the posts and appropriate washers. I had to grind some a bit shorter so they wouldn’t come through the front but it wasn’t a problem. You can’t tell and it looks good even on the inside. 2012 5.0 SC AB
Wed Jul 15 2020 8:04pm |
Thanks for that. Sounds like I need to find a salvaged card and strip that. I need a few parts now to get the car up to standard but on the whole its pretty good. I am just being very fussy.
Thu Jul 16 2020 3:18pm |
