![]() | Home > Faults & Fixes > Gurgling from behind the dash. |
HughN Member Since: 10 Sep 2017 Location: Near Llanybydder Posts: 651 ![]() ![]() |
It looks like the brake vacuum pump has filled the servo with oil. When the ignition is switched off the vacuum is lost and air bubbles through the oil as the pressure equalises. Recall P017 on the D3 refers. |
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 410 ![]() ![]() ![]() |
@HughN
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4527 ![]() ![]() ![]() |
New vacuum pump and servo required |
Mikey... 2-3 hours labour at a garage?
It only seems to be when the key is switched to 'off', irrespective of where the pedal is. HTH |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5123 ![]() ![]() ![]() |
Ask the dealer to do recall p017 if it hasn’t got twin vacuum pipes from the engine |
I think it has, Andy.
All fixed (eventually). |
