Home > Faults & Fixes > Gurgling from behind the dash.
HughN
Wales
I haven't been driving my car for a while (no work to go to Big Cry ) but when I have I've noticed a strange gurgling sound from behind the driver's side of the dashboard when the engine is switched off.
The coolant level is correct and I have run the engine with the cap removed and the heating on full blast until the fan kicked-in - no change.
All suggestions welcome!
Post #600693 Tue Jun 23 2020 6:48pm
HughN
Wales
It looks like the brake vacuum pump has filled the servo with oil. When the ignition is switched off the vacuum is lost and air bubbles through the oil as the pressure equalises. Recall P017 on the D3 refers. Censored
Post #601709 Tue Jul 14 2020 2:51pm
BJH1959
Portugal 2005 Range Rover Sport TDV6 HSE Cairns Blue
@HughN
Does the gurgling noise happen on its own, or does it only occur when you depress the brake pedal with engine off?
Thanks Barrie.
2005 RRS 2.7TDV6 from 2017 -2024. Best car I ever had.
Current: 2018 Ford Ranger Wildtrak 3.2
Post #601767 Wed Jul 15 2020 6:06pm
Disco_Mikey
New vacuum pump and servo required Neutral
Post #601774 Wed Jul 15 2020 6:44pm
BJH1959
Mikey... 2-3 hours labour at a garage?
(HughN - apologies for hijacking your post. Mine went today!) Barrie.
Post #601775 Wed Jul 15 2020 7:05pm
HughN
Wales
BJH1959 wrote:
@HughN
Thanks
It only seems to be when the key is switched to 'off', irrespective of where the pedal is.
HTH
Post #601776 Wed Jul 15 2020 7:19pm
Ask the dealer to do recall p017 if it hasn’t got twin vacuum pipes from the engine
Post #602102 Fri Jul 24 2020 8:02am
HughN
Wales
I think it has, Andy.
How much of a PITA is changing the pump? I can't remember exactly, but suspect it is at the back of the engine somewhere.
Post #602105 Fri Jul 24 2020 9:56am
HughN
Wales
All fixed (eventually). Thumbs Up
By all accounts, replacing the brake vacuum pump at the back of the engine was a pig of a job but was just about possible without lifting the body or dropping the engine and/or gearbox.
Removing the brake servo was equally a pain, with the fixings spinning. I believe the fixing involved some 'open-heart' surgery of the servo and welding them so they didn't spin.
All that matters is I have my car back - so much nicer to drive than my wife's D4 - and now with very sharp effective brakes.
Post #603877 Fri Aug 28 2020 3:35pm
