Home > My Range Rover Sport > My First RRS!
PeteF74
United Kingdom 2011 Range Rover Sport SDV6 HSE Lux Orkney Grey
My First RRS!
Hi Everyone.
I've just bought this Orkney Grey RRS 2012MY. Its my first RRS but years ago I used to own a RR Classic 3.5 Vogue. I am chuffed to bits with my RRS but wanted to see what peoples thoughts were on having a precautionary gearbox service (LR say its sealed so don't do it?) and any other precautionary work I might need? Lower suspension arm bushes? Does the whole arm have to be replaced?
Its got a full LR history, 2 previous owners and 74k miles and has had the belts done, everything works and I want to keep it that way!
Also if anyone can recommend a good specialist in the South Wales area that would be great. Thumbs Up
Pete
Post #601219 Fri Jul 03 2020 1:37pm
PeteF74
Sorry, here it is... just getting used to the forum!
Post #601220 Fri Jul 03 2020 1:40pm
Ignore LR's advice not to do it. Get it mega-flushed as soon as possible as you're at the tail end of the time that ZF (who make the 'box) recommend for a fluid change. Just dropping the oil from the drain plug doesn't change much which is why a flush is needed.
Bristol Transmissions do gearbox flushing, I believe, if you can't find an indy in S Wales.
Oh, and welcome to the club Thumbs Up
Edit: the arms can have the bushes replaced but it's often cheaper to just swap the whole arm. That way you replace three wearing components in one go. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #601224 Fri Jul 03 2020 1:50pm
PeteF74
Thanks Very Happy Its good to be here.
I had been reading about gearbox services and what a good idea it was but then I spoke to LR the other day and they said don't touch it as it causes more problems. Left me a bit confused.
Roughly how much does a flush cost and how long does it take??
Sounds as if that's going to be a priority job Thumbs Up
Post #601227 Fri Jul 03 2020 2:05pm
DrRob
Ignore their advice. Lot of cars been flushed with no issues. Bodsy in Telford is a mobile guy and I would highly recommend you use him. No need to drive anywhere either Thumbs Up
07770638023. Tell him we sent you Thumbs Up
He will also do a fault code check for you and other stuff like diff oils, transfer case oils. Do them all! * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
I use www.glenrands.co.uk Great independent
Post #601235 Fri Jul 03 2020 5:53pm
DrRob
Contact Paul at site sponsor Advanced Factors to chat arms. He does updated ones Bow down Thumbs Up * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
Post #601236 Fri Jul 03 2020 5:54pm
Stevepd
Hi and welcome. If the belts are done then yes get the box flushed which is around £270, worth every penny. Consider the fluid changes on the diffs and transfer box if it’s not mentioned in your paperwork. Apart from that wait for items to be picked up as it’s serviced. These are great cars and enjoy another way of getting there Thumbs Up . 2006 2.7 TDV6 HSE in Cairns Blue.
Post #601239 Fri Jul 03 2020 6:58pm
knwatkins
As above, definitely get the fluid changed in the autobox. I know you said it has full LR history, but it's worth checking what was done/not done so you can make sure it really is tip-top for you going forward.
There's no point in replacing the bushes in the arms unless they are giving you problems. A quick dab of the brakes will cause a knock if they are worn. The rearmost bush in the front bottom arms is the hydrabush that is prone to wearing prematurely. As Rob mentioned above, Advanced Factors manufacture their own arms with a solid rubber, heavy duty bush manufactured by Meyle. These are the most robust ones on the market and many of us have these fitted.
You don't necessarily need to buy whole new arms and you can buy the Meyle HD bushes on their own, but it's the time and hassle of cutting the old ones out and pressing the new ones in versus the convenience of just fitting brand new assemblies.
Good luck with your new toy and welcome to the forum Thumbs Up Kev
Post #601242 Fri Jul 03 2020 7:57pm
The first rule of RRS club is: don't go to LR dealers.
The second rule of RRS club is: don't go to LR dealers.
Find a decent indy.
LR dealers are about as much use as a Russian tourist guide of Salisbury. 2012 SDV6 - it's missing a couple of cylinders
Post #601252 Fri Jul 03 2020 10:16pm
PeteF74
Rolling with laughter Rolling with laughter Rolling with laughter Great rules! now before anyone thinks I am going to the main dealers and I get a pasting on here, I only rang them to find out what work had been done over the years and to be fair to them they were helpful telling me.
Going forward I will be looking for a good indy. Thumbs Up
Thanks for all the advice. I will definitely get the gearbox done to keep it healthy. The bushes can wait as there aren't any clonks and the tyres are wearing evenly.
Does anyone know if you can get the rear door speaker grille off without taking the door pad off?
Post #601267 Sat Jul 04 2020 11:06am
knwatkins
I don't think so. It's only a few clips and screws to remove the doorcard though. Kev
Post #601268 Sat Jul 04 2020 11:12am
Wafoo
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Baltic Blue
Re: My First RRS!
PeteF74 wrote:
Hi Everyone.
Pete
Promec in Gros Faen are very good, know there stuff, not the cheapest but not the most expensive either, done my handbrake and in for ACE pipes this week
Post #601304 Sun Jul 05 2020 9:26am
PeteF74
Thanks for that. I used to live in Creigiau but never knew of Promec.
Post #601465 Thu Jul 09 2020 12:19pm
PeteF74
I spoke to Bristol Transmissions about the gearbox flush and they said that ZF recommend it at 80,000 miles, so I am going to get that done. I am on 74k now so have some time for that one. Their price didn't seem to bad either. Has anyone on here used them? they seem to have good reviews.
Promec were a bit dearer but closer to home and the guy there was very helpful explaining what to do about my rear end dropping Shocked lol Laughing
Post #602171 Sat Jul 25 2020 12:19pm
DrRob
Bristol Transmissions have a rock solid reputation Thumbs Up
Promec have a Megaflush according to their website so I’d go there. Less diesel Rolling with laughter * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
Post #602200 Sat Jul 25 2020 3:52pm
