Home > Technical > whats this levers function |
david007 Member Since: 20 Jun 2017 Location: Forfar Posts: 166 |
Think it’s the headlamp leveling sensor.
Sat Jun 20 2020 2:28pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4790 |
It controls the height of the suspension.
Sat Jun 20 2020 2:48pm |
kenpassey Member Since: 03 May 2018 Location: Liverpool Posts: 33 |
Thanks Lads for the reply regarding the lever.. appreciated. As for my starter motor click, i swapped R6 Relay with a compatible one from the fuse box but it made no difference, i have still not located the earth point, yet i will remove the wheel tomorrow.
Sat Jun 20 2020 3:59pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8844 |
The device in your photo is the ride height sensor for that wheel. The car uses it to determine the wheel's vertical position when changing the height from access to normal to off road heights amongst other things. 2012 SDV6 - it's missing a couple of cylinders
Sat Jun 20 2020 6:17pm |
hairy Member Since: 02 Feb 2020 Location: aberdeen Posts: 31 |
I had exactly the same problem, had to replace the starter.... |
Sun Jun 21 2020 7:08am |
thanks, i think it will end up being replaced. cheers |
Sun Jun 21 2020 12:33pm |
Just a quick question on the starter motor the large lead is the power.. is the smaller plastic connection to earth. Thanks |
Sun Jun 21 2020 3:53pm |
The small wire requests the starter to turn.
Sun Jun 21 2020 4:53pm |
