![]() | Home > Faults & Fixes > Strange sound and issues |
If the limiter sound, sounds like a chuffing noise then I’d suspect a split pipe or manifold. No power could be symptom of a seized turbo actuator. 2019 5.0 SC SVA (Current)
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9119 ![]() ![]() ![]() |
Black smoke means over fuelling which is one symptom of a split intercooler hose. 2012 SDV6 - it's missing a couple of cylinders
Are you taking your car to LR indies or service anything types? 2006 2.7 TDV6 HSE in Cairns Blue. |
Good question. A "garage" doesn't cut it, generally. It needs to be a LR specialist. 2012 SDV6 - it's missing a couple of cylinders
Warlowg Member Since: 14 Mar 2020 Location: Wiltshire Posts: 8 ![]() ![]() |
I’ve not taken it to a LR specialist but I think that’s what I’ll do next.Has anyone had failed injectors and know what the symptoms are with these?I had a new turbo pipe fitted and will now mention what you guys have said in case that’s something they have missed |
