| RRSPORT.CO.UK | ||
|  | Home > General > creaking squeaking noise only in hotter weather |
| knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139      | I would say arb bushes also. It could be any bushes though. Kev
|  Tue Jun 09 2020 12:36pm |
| abiopete Member Since: 27 Feb 2020 Location: Manchester, UK Posts: 184      | Had my ARB bushes done a couple of weeks back, made a big difference although not totally gone. There's defiantly something else needs doing L494 3.0L SDV6 Autobiography MY20 in Eiger Grey (Current)
|  Tue Jun 09 2020 12:45pm |
| Tyrefitter Member Since: 19 Jul 2015 Location: Bridlington East Yorkshire Posts: 3677      | Spray your suspension rubbers with WD40 & it could stop the squeaking,i get loads of vehicles in this weather with the same problems. Andy.
|  Tue Jun 09 2020 1:56pm |
| abiopete Member Since: 27 Feb 2020 Location: Manchester, UK Posts: 184      | Would silicone spray be better do you think? Might give it a bash.. L494 3.0L SDV6 Autobiography MY20 in Eiger Grey (Current)
|  Tue Jun 09 2020 3:47pm |
| Tyrefitter Member Since: 19 Jul 2015 Location: Bridlington East Yorkshire Posts: 3677      | Silicon spray is fine,I use wd as I buy it in gallon cans. Andy.
|  Tue Jun 09 2020 4:09pm |
| knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139      | Silicone will be better than WD40 on rubber. Kev
|  Tue Jun 09 2020 5:07pm |
| arinb12 Member Since: 09 Jun 2020 Location: london Posts: 6    | thanks guys, will try that.
|  Tue Jun 09 2020 5:29pm |
| knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139      | It's not that it's expanding in the heat. In fact, rubber actually has an interesting characteristic that causes it to contract as it gets warmer, unlike most materials. This is due to its unusual polymer structure.
|  Tue Jun 09 2020 6:28pm |
| arinb12 Member Since: 09 Jun 2020 Location: london Posts: 6    | So I've narrowed the noise down. It's coming from the front centre. I have sprayed every bush on the front end with wd40. Today it was crazy squeaky after a nice long long drive that got the engine nice and hot (the weather was not the usual hotness that was making it happen almost immediately before)
|  Sun Jun 14 2020 3:37pm |
| arinb12 Member Since: 09 Jun 2020 Location: london Posts: 6    | Also what's the chances the active arb has failed and that's causing the squeak? What is the symptom of failed active arb? | ||
|  Sun Jun 14 2020 3:49pm |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159      | The ARB leaks when it's failing. It's just a glorified hydraulic ram basically. 2012 SDV6 - it's missing a couple of cylinders
|  Sun Jun 14 2020 7:05pm |
| Spangler Member Since: 02 Mar 2019 Location: Kent Posts: 98      |
 Long shot but if the noise is from centre front could it be radiator/condenser fixings? Have no idea if they have rubber around the fixings (and cant be arsed to look lol) but what else is located in this position? | ||
|  Sun Jun 14 2020 8:36pm |
 How do you do this? L494 3.0L SDV6 Autobiography MY20 in Eiger Grey (Current) L494 3.0L SDV6 Autobiography MY14 in Chile Red L320 3.0L SDV6 Autobiography MY10 in Baltic Blue (RIP first RRS love 29/03/2021 insurance total loss) | ||
|  Mon Jun 15 2020 7:17am |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156      | Have a look under Suspension Section of Owners Handbook poss. page 83 tells you which sequence of buttons to press on the key fob.
|  Mon Jun 15 2020 7:34am |
| Posting Rules
