![]() | Home > General > creaking squeaking noise only in hotter weather |
I would say arb bushes also. It could be any bushes though. Kev
abiopete Member Since: 27 Feb 2020 Location: Manchester, UK Posts: 169 ![]() ![]() ![]() |
Had my ARB bushes done a couple of weeks back, made a big difference although not totally gone. There's defiantly something else needs doing L494 3.0L SDV6 Autobiography in Chile Red (Current)
Spray your suspension rubbers with WD40 & it could stop the squeaking,i get loads of vehicles in this weather with the same problems. Andy.
Would silicone spray be better do you think? Might give it a bash.. L494 3.0L SDV6 Autobiography in Chile Red (Current)
Silicon spray is fine,I use wd as I buy it in gallon cans. Andy.
Silicone will be better than WD40 on rubber. Kev
arinb12 Member Since: 09 Jun 2020 Location: london Posts: 6 ![]() ![]() |
thanks guys, will try that.
It's not that it's expanding in the heat. In fact, rubber actually has an interesting characteristic that causes it to contract as it gets warmer, unlike most materials. This is due to its unusual polymer structure.
So I've narrowed the noise down. It's coming from the front centre. I have sprayed every bush on the front end with wd40. Today it was crazy squeaky after a nice long long drive that got the engine nice and hot (the weather was not the usual hotness that was making it happen almost immediately before)
Also what's the chances the active arb has failed and that's causing the squeak? What is the symptom of failed active arb? |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9069 ![]() ![]() ![]() |
The ARB leaks when it's failing. It's just a glorified hydraulic ram basically. 2012 SDV6 - it's missing a couple of cylinders
Spangler Member Since: 02 Mar 2019 Location: Kent Posts: 98 ![]() ![]() ![]() |
Long shot but if the noise is from centre front could it be radiator/condenser fixings? Have no idea if they have rubber around the fixings (and cant be arsed to look lol) but what else is located in this position? |
How do you do this? L494 3.0L SDV6 Autobiography in Chile Red (Current) L320 3.0L SDV6 Autobiography in Baltic Blue (RIP 29/03/2021 insurance total loss) |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5081 ![]() ![]() ![]() |
Have a look under Suspension Section of Owners Handbook poss. page 83 tells you which sequence of buttons to press on the key fob.
