Home > General > Changing front drop links
micknolan
Just a quick question before I change front drop links, can I change with wheels on with or without jacking up.
As I think I read some where both wheels need to be off ground because of tension on ace bar
As I was going to jack one side up and change with wheel off ?
Thanks
Post #600204 Sat Jun 13 2020 9:02pm
knwatkins
Never trust a jack alone. Always use stands.
And if you're using stands, you may as well lift both wheels up. Kev
Post #600212 Sat Jun 13 2020 10:59pm
micknolan
Thanks for advice 😁
Post #600213 Sat Jun 13 2020 11:03pm
Brit Plumber
And don’t forget the cars can re-level automatically so if you’re underneath the car without a stand but on the wheel, it could drop as part of its self levelling, even with the car locked. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #600220 Sun Jun 14 2020 9:48am
knwatkins
That's a good point, Chris. I always remove both air suspension fuses from the engine bay fuse box when I'm working on my vehicle. Better to be safe than sorry. Kev
Post #600221 Sun Jun 14 2020 9:52am
micknolan
All done, just a heads up to any one doing them you’ll need a 21mm open ended spanner and a Alan key to stop them spinning when taking nut off
Thanks 😊
Post #600232 Sun Jun 14 2020 1:27pm
knwatkins
Well done. Were they knocking? Kev
Post #600250 Sun Jun 14 2020 8:27pm
micknolan
Seemed liked bushes but changed drop links as I had them from some time back, and it was them
All back to normal for a bit 😁
Post #600251 Sun Jun 14 2020 8:30pm
knwatkins
Great news Thumbs Up Kev
Post #600253 Sun Jun 14 2020 8:34pm
