Home > General > Little update
Philcaz
United Kingdom 2007 Range Rover Sport Supercharged Java Black
Little update
Hi guys
Thought I'd let you know how the sport is going to be honest I love it I should have bought one years ago only thing I've noticed is a little knock over bumps from the front not bad but I can hear it on the mot it says front lower bushes slight play so I'd think it was that knocking
Cheers Phil
Post #600072 Thu Jun 11 2020 1:06pm
mrluke
Mine was nocking when turning .
Get the ARB bushes done when you have the lower arms replaced Wink
Post #600117 Fri Jun 12 2020 9:13am
Philcaz
Thanks for the tip mate I'll get them done as well
Phil 👍🏻👍🏻
Post #600122 Fri Jun 12 2020 9:51am
Drive along at 10mph and give the brake pedal a firm quick prod, if you hear a knock then that's the lower front arms. 2012 SDV6 - it's missing a couple of cylinders
Post #600129 Fri Jun 12 2020 12:05pm
Philcaz
Hi mate
Yeah I've done that and I can hear and feel a little knock seems like your spot on
Phil
Post #600133 Fri Jun 12 2020 12:38pm
DrRob
Advanced Factors do uprated lower arms that are superior and last longer than standard. Talk to Paul Redding there Thumbs Up * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
I use www.glenrands.co.uk Great independent
Post #600144 Fri Jun 12 2020 5:31pm
Philcaz
Cheers mate
I'll give them a bell
Phil
Post #600145 Fri Jun 12 2020 5:41pm
This is the kit I used from A/F, fitted spot on, tried the kit with the poly bushes first, but found them a little to harsh for my liking so fitted the Meyle kit instead.
https://www.advancedfactors.co.uk/kit630-h...7241-p.asp
Post #600161 Fri Jun 12 2020 10:57pm
knwatkins
I also have the Advanced Factors arms with Meyle bushes. Recommended Thumbs Up Kev
Post #600165 Sat Jun 13 2020 8:05am
