![]() | Home > General > Little update |
mrluke Member Since: 22 Apr 2018 Location: Essex Posts: 270 ![]() ![]() |
Mine was nocking when turning .
Philcaz Member Since: 15 Apr 2020 Location: London Posts: 68 ![]() ![]() ![]() |
Thanks for the tip mate I'll get them done as well
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9077 ![]() ![]() ![]() |
Drive along at 10mph and give the brake pedal a firm quick prod, if you hear a knock then that's the lower front arms. 2012 SDV6 - it's missing a couple of cylinders
Hi mate
Advanced Factors do uprated lower arms that are superior and last longer than standard. Talk to Paul Redding there |
Cheers mate
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5081 ![]() ![]() ![]() |
This is the kit I used from A/F, fitted spot on, tried the kit with the poly bushes first, but found them a little to harsh for my liking so fitted the Meyle kit instead.
I also have the Advanced Factors arms with Meyle bushes. Recommended |
