![]() | Home > Maintenance & Modifications > Post service advisories - UPDATE |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 954 ![]() ![]() ![]() |
The only thing thing that really stands out is the Gearbox flush. I would expect £275 give or take a few quid to have that done,,,and that is a proper flush not just a drain and refill. Lower arms etc probably not too far away, 4 wheel alignment has to be done after fitting front arms which is par for the course and I suppose depends on where you purchase the propshaft from Regards that bit.yy 2010 RRS, TDV8
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4511 ![]() ![]() ![]() |
Propshaft is very expensive
skid1963 Member Since: 24 Mar 2018 Location: Snodland Posts: 219 ![]() ![]() ![]() |
Gearbox flush waaaaay over the top, got mine done for £250
Gearbox megaflush too pricey. Call Martin Hind at Dartford Transmissions and Autocare. Ex LR mechanic, gearbox guru and LR enthusiast |
1richard1 Member Since: 10 Sep 2019 Location: oldbury Posts: 178 ![]() ![]() ![]() |
Looks like the start of make up for lost trade post lockdown. |
Spangler Member Since: 02 Mar 2019 Location: Kent Posts: 98 ![]() ![]() ![]() |
Agreed - done some price checking online and the propshaft is at least £100 more expensive than what I could source, and they are doubling up the labour hrs on the cv joint and wishbone work too. |
When I was asking about the gearbox flush I did ask if it was around £300 as that's the £ I've seen quoted on here quite alot - when he looked it up on the computer and came back with £850 I was gobsmacked!! The mechanic did go on to explain why it was so expensive as it does this an that but to be honest I wasn't listening as still trying to get my head around the price... ![]() It was Dakar 4x4 in Swanley who I took it too - wanted to go to AHL but I also needed new rear discs and pads fitted (which I had bought off a forum member) but they wouldn't fit them as they were not supplied by them. Looked Dakar up on the forum and only saw positive feedback so went there instead as the discs needed doing. |
Funnily enough I believe he used to work at Dakar 4x4 !! I've contacted AHL Engineering in Maidstone requesting a 2nd opinion and pricing. Hopefully they'll agree and I at least know what's is really required. With all the lockdown impact I can see some garages having to make up lost income and pricing / repair work to take a step upwards.... |
While I cant speak for other garages, I haven't seen the need to put my prices up. We are still just as busy as ever, with the diary now full for at least the next 3 weeks, not including as many as 5 engine replacements
FWIW, we also don't fit customer supplied parts. Our insurance company specifically prohibits us from doing so. If we do fit customer supplied parts, we are not covered for liability should anything unforseen happen. Its not worth the risk ![]() |
Just thought I'd share an update on this after taking the car for a 2nd opinion as I wasn't convinced what was flagged up was required.
Excellent result |
Being honest on the zero fault codes - was really surprised myself when I heard it.
